As English is my strong suit, I suck at math. I measured a church sanctuary today and usually I just break it up and measure the squares but this one was shaped strangely and I don’t know how to calculate the footage. The center section is 63x46. Then what? Someone help.
Is that a question or is that the answer?7,980 sq. ft. ?
Have you seen the size of that dude? there's no way he's going to rip through it like the stealth little tap dancer you areEight hours?
Scott better buy a couple of machines to cut that puppy down to size.
He's a worker, that guy just works hard.Have you seen the size of that dude? there's no way he's going to rip through it like the stealth little tap dancer you are
I thought something like that. I did measure a diagonal but then couldn’t remember why I needed to. Deep down I must have known how but it’s been a lot of years. This is the first time in 3 years of quoting commercial carpet that I haven’t had a clue where to begin calculatingYou need angles to solve for an irregular quadrilateral afaik........
edit: I guess it can be done in some cases
He’s a beast, Mikey. He’s fast.Have you seen the size of that dude? there's no way he's going to rip through it like the stealth little tap dancer you are
It's a question.Is that a question or is that the answer?
He can use one with each hand.Eight hours?
It's not like you're replacing the carpet. so getting the exact square footage isn't going to affect the customer's or your income. I have a church shaped like that and I just do an average square footage if it was just a rectangle. I suck at math also.I got 1672 for the hallways so I made the estimate for 9600
Ummmm...Quick way to get a ballpark is to just average the 2 irregular sides.
So box one:
40+46÷2 = 43
56+63÷2 = 59.5
43 x 59.5 = 2558.5 (close enough for carpet cleaning)
Some get it.that is just the left box
and some charge by the hour..Some get it.
