Fire hydrant to garden hose connector
Just in case..
do you carry the 600ft of garden hose run to across the street and down the block
and the bigazz wrench too?
Bc
Eckman gave it to me..
He moved to Ashville NC today...
Had tacos, and way too many tequila shots, and margaritas with Jimbo…
A very memorable night for sure.
The guy has a great personality and some cool stories…
San Francisco, CA.
You will need to have a permit from the water company which should include a water meter on the set-up; otherwise, you are stealing water.
I use to have such a set-up.
you don't have to open the valve all the way
....unless you need 500-1500 gpm flow
If I can understand this,
They're not high PSI, just mega flow rate
appears the PSI isn't all that great and wouldn't burst a garden hose
(fire truck pumps is what boosts the PSI)
donno if many CC'ing jobs would be worth the PITA though.
"Is there water anywhere in the facility?
OK, lemmie know when there is"
