- Oct 6, 2006
- 117,010
If any....?
They do is supposedly a 3 jet and run it at 600 psi to achieve their 250 degree at the wand temperature. Per “Wayne’s” book of jet knowledge.
True…The number of jets has nothing to do with volume output
lots of requests for a GGlide for that wand.The unit I have came with a sharp shooter 2 jet wand. Same shit as the evolution wand with a split in the middle of the head.
You know it. And it’s been used once and is already curving. Same thing happened to my 16 inch evolution when I had it.lots of requests for a GGlide for that wand.
Im guessing they used the same triangulated Delrin glide as the HM stairtool, right?
Bowing in which direction?You know it. And it’s been used once and is already curving. Same thing happened to my 16 inch evolution when I had it.
In a U shape. When I put it on a flat surface the corners are not flush to the table.Bowing in which direction?
Yes there is foam behind the glide. Here are some pictures of the wand. Tried to show what I could on a flat surface. It won’t make much difference in plush carpet but as it gets used will now more.foam gasket on the back side?
View attachment 111948 View attachment 111949 View attachment 111950
Yes that’s what came with the truck and to be honest didn’t care if a wand did or didn’t. I have what have and like it. So didn’t make too much of a big deal about it. If I had a choice it would have been some type of ti wand and would have paid the difference or just got credit without a wand. Will probably end up selling or giving it to another cleaner.yikes
So that's the one that came with the truck mount, were you giving any other choices?
Good news, the DDS does have a low water shutoff. It also has the in -line filter but it's a little different than the Evererest. It's more cylindrical.A filter box just like the everest. A low water shutoff water pump switch on the hot water box or water tank, whichever one feeds the water directly in the water pump.
