- Oct 6, 2006
- 117,214
Hmm..maybeHeat?
It doesn’t just vacuum out?I run plastic air induction nozzles on my OP machine, puts out same volume but with the fines removed so not encapping my lungs
how?I would grind those to a nub in a day
The devil is among us
I figured you could relate...That was actually funny
Link?I run plastic air induction nozzles on my OP machine, puts out same volume but with the fines removed so not encapping my lungs
Link?
I’m sure those red nipples will be fine for my PHX…![]()
TeeJet AI Nozzles
TeeJet AI Nozzles (Air Induction Flat Spray Tips) Typical Applications: See selection guide for recommended typical applications for TeeJet AI tips. Features: ♦ 110º or 80º wide, tapered flat spray angle with air induction technology offers better drift management. Optimal height 20″ and 30″...flsprayers.com
yellows are 02 nozzles, being long they will need angle changed slightly or can buy offset angles etc
they also have a nozzle body that the tips fit into which extends them bit more again.I’m sure those red nipples will be fine for my PHX…
Thank you Dan..they also have a nozzle body that the tips fit into which extends them bit more again.
I'll get pic of mine when at my lockup later
never used anything from releasit family, but encap spiked with isop makes me gasp and wheezeIt doesn’t just vacuum out?
Must have used Releasit DS1 with tea tree.. Works well but almost got kicked off 3 jobs for atomizing it..![]()
