I hate that I waited so many years to use jet extenders
MLPW
On my prochem titanium.
1” was put on and I can tell a major improvement in the shearing. I’ll be posting more on this thread over the next few weeks to give more feedback on how much it improves my cleaning
Reactions: Living The Dream
red tip on a pressure washer and a higher flow to a white tip.
I believe the "flow" is the same, it's the jet angle that concentrates the flow tighter.
same effect going from 11502 jet to 6002
I dumped my Ti wand extenders.
They didn't stop the wand dribbles for more than 20 minutes use , didn't deliver any more heat to fiber and made no difference in cleaning.
add the carpets you had to PSI down to 300 to prevent jet distortion...
I determined they're just another board de jour bundle of worthlessness
MLPW
I always hated the vac tube being in the way of the 2 middle jets without extenders. I'll try several different setups this week and see what I find out. I wasn't concerned about heat or wand dribbling. I'm really just wanting a better impact on the carpet to flush it more efficiently.
And as for the flow...a 95015 is different flow than a 9502. I was referring to the 15flow causing more distortion due to the spray being sharper, like a red tip on a pressure washer
MLPW
I feel as if you may be including me. I use Devastator’s. You should also. Then you wouldn’t worry about wand jet physic’s.
Will you Show me the water spray on the two middle jets? I’m curious if the vac tube interferes with the spray like all the other 4-6jet wands
Nevada
Have you ever used a devastator? I have...I'm a believer...all your questions has already been answered and implemented...
