I'm not going to encourage it because most of the people are idiots
But if you know how to positively ID wood floors and you can figure out how to get your wand to spray out 75 PSI, these fooking brush glides are amazing on wood...
my pressure regulator vibrates off the 370 TM if below 300 psi. 😱
guess I won't be doing wood floors.
tell us more
Why tell when I can show..
Rob Grady
Rob Grady
Tap water pressure in our area is around 40-50 psi. I built a water box with a 100 psi demand pump to feed from sink taps. Maybe that would work?
Can't I just cut off all the flow to my tile wand?
First off, you probably don't own a tile wand and if you did you wouldn't want to use the piece of shit just like me and I've owned them all. Why do you think I came up with this green brush glide anyways
Reactions: bob vawter
Nah...I don't own one but have used a few over the years
Because there was nothing "new" in the greenglides lineup and of course you wanted something you could say you invented? Just guessing here
Idiotā„¢
Now see? I’ve never said I had issues, but you’ll have a chip on your shoulder from now on.
chip?
why, you're opinion is worthless.
You dont know shit about hard surface work.
The gym floor is impressive. At least he could have got her a 15ā€ crb. You do know an auto scrubber would have done it in a tenth of the timešŸ¤·šŸ¼ā€ā™‚ļø Time is moneyšŸ˜¬šŸ˜‰
Rob Grady
Rob Grady
Why wouldn't you just use a crappy little sprayer and a cloth to achieve your 'deep cleaning'?
.....and you STILL come here for affirmations Mike?
I accomplish a whole other market share study here.
50-70 yo wornout self professed geniuses.
On another note, Im almost there with the AW29 conversion.
Sheer kit with new jets and a wider HS Glide will make this the best seller by far. The inherent light weight and small size of the AW will make for an excellent resi HS wand.
Based on requests from all corners of the market, I'm pretty Fn excited.
