My dryer vent need a high colonic...
It's never too late to be nice to your fellow humans, so why don't you rent a VRBO in the Ukraine to earn some karma points
You should see the Air BnB I did on Tuesday. It was awesome. Right on the river in Castella. The owners own 8 of them and make serious bank. I may need to get into this.
Numero Uno
Caesar
Hit a nerve ,huh...
Poor widdle nobody...
Drink some wd 40...
Your squeaking...
2 ply...
Tell us more on your knowledge of bags...
Meester Douche...
:eekk::eekk::eekk::eekk::eekk::eekk::eekk::eekk::eekk::eekk::eekk::eekk::eekk::hopeless::eekk::eekk: PXL_20220308_233531364.jpgPXL_20220308_234901950.jpgPXL_20220308_235602009.jpgPXL_20220308_235653862.jpg
We have two dryers/ vents. One for carpet cleaning rags and one for our household stuff. The smaller bundle of goodness is from the household...
I entered one side with 1.5 inch vac hose hooked to the 370Tm and used a Doggy blow dryer from other end to clean dryer vents.
Acp
Bjorn Marshall
we do lots of dryer vents. if you have a decent air compressor you just need a non rigid air line and a reverse skip ball. You can put your air line through a small wiffle ball to help bend corners if needed. small compressors wont work you want at least 150psi
If you're blowing out all the way, how do you go about containing it and what do you charge prevent and what liability do you take on if a pipe comes loose..
KevinD
Kevin Dumas
You guys need better designed places for laundry rooms.
My dryer vent is exactly 18 inches. Straight out a exterior wall.
