I sure wish one of you fn people was a wands geek
I do. I've been ordering Greenglides for 18 years from Lisa. This is actually what they call the "look a like" Hydrahoe made by PMF. The external is a perfect fit. I've never tried the internal one but I would be glad to give it a try.View attachment 113611View attachment 113612
The PMF wand is still in production and is actually the exact same wand.
Hydromaster discontinued it a while back in favor of their Evolution line.
I sell mostly internals as they help keep the older HM wands from pinching shut, the PMF version has a support pin in the middle which does the same thing.
Reactions: Jim Williams
Meter Maid
The Undetective
Dayton,Ohio
I’m a wand idiot.
In 4 years, I’ve owned and extensively used:
Bentley
Mytee Speed Wand
Dev12
JoeDang
Evo13 & 16 & stair wand
Mach 12 2”
SS12
Zipper 13”
Only the Evo13, Evo stair wand, Mach 12 and SS12 get used.
I’m a wand idiot.
Bentley
Mytee Speed Wand
Dev12
JoeDang
Mach 12 2”
SS12
Zipper 13”
Thanks for the order today by the way.
I put some used underwear in the box for you.
Have you tried the Hybrid Glide for the Evo 13?
Reactions: Meter Maid
Meter Maid
The Undetective
Dayton,Ohio
I have your slot glide on it. Completely changed the wand.
If the brush glide pops on and off the SS12 fairly easy, I’ll get the slot glide for it also.
The hybrid format seems like a great idea, but don’t the slots get the majority of the airflow, since air looks for the path of least resistance?
The Hybrid reduces chatter even more on that wand, while increasing vacuum by restricting the voluminous air flow in that giant head
Numero Uno
Ma
Caesar
Have Butler single jet with glide in basement also ...pretty much brand new used very seldom back in the day. O-rings probably shot but sill good.
Meter Maid
The Undetective
Dayton,Ohio
Do you recommend 80 jets on the SS12 carpet glide also? The stock glide is pretty thick and the 95s are about right with the stock glide.
Slots are too big though.
For sure. 80015 all the way across
Is your SSTI Glide internal or external fit?
The internal is easier to swap out if you remove the back metal lip.
Oh.. wow..
Yeah you will be amazed at the difference. Haven't you noticed that the external is rocking of and on the back lip? and leaking air...
The “other” glide companies say leaking air is good😏
Screw that. Give me a tube of silicone
