AW29 super fans
A huge step was accomplished in getting one step closer to a GreenBrushGlide for the infamous AW-29 wand.
Maneuvering the spray jets to sheer/strike right behind the Glide was a big accomplishment.
In this process I have an adaptor kit which would be PERFECT for a person who DOES NOT use a carpet Glide on this wand.
If you clean with this wand every day, on every job and have a critical eye for detail and think your cleaning process would benefit from having the jets strike much closer to the vacuum slot, please chime in, as I'm looking for a BETA tester.
Meter Maid
The Undetective
Using that wand for a couple weeks is what got me to realize wands make a huge difference in performance.
At least it was good for that.
Yep, it's horrible but it's the best selling one in this industry and my second best selling glide for what it's worth
Meter Maid
The Undetective
Aren’t they free on just about every machine out there? Maybe those are counted as sales.
Meter Maid
The Undetective
Then that’s probably not the one that came with my machine. I stand corrected.
I use my aw29's almost daily. Both are glided and an talking to my next door fabricator about cutting my supply lines and installing a sheer kit so that the cleaning solution hits at an aprox 45 degree angle. If you've already done this, I will gladly test it for you
Ive got a one beta kit to be used with Glides, and two kits that should work without a glide, for now...
My idea for a sheer kit was just to cut the supply lines, install flare nuts with 1/4 inch npt fittings, 45 degree elbows and t jets. My fabricator wants to weld stainless fittings that the elbows and jets can be mounted on. Either way, should be adjustable to hit just in front of the glide.
