the new 12 inches 3 jets butler carpet wand
Margarito aceves
hello guys does any one here try this wand before and if so how it does retaining the heat and air flow,i really like to try it out and see how it works compare to my 4 jets and 2 jets that i currently use thanks..
Numero Uno
Caesar
All I ever used since 80.Still works great -upgraded to soft touch valve first yr .Butler offered...Very well made ,single easy to clean slot...With green glide by Jeff and Lisa even nicer...To each there own.But John Henry never ever failed me.Yes I named it lol...Used just the other day actually .We have larger Butler wands ,and a sapphire wand as well. Butlers larger version destroys shoulders on huge square foot jobs...Smaller gets me around and under and in better.Regards ! Own 2 ,the other is Butler single jet, seldom used...Both roughly 40 to 30 yrs old... Although huge fan of evo -here. light and just as nice. Prior to Butler I used Bane .
Margarito aceves
thanks for the feed back i have another fella that runs a butler and he says the same thing bullet proof hes been using the same wand since the earlys 90s
You might want to post a pic.
sassyotto
Paul
so is this a 2 inch tube? If not, what size and will it fit directly to a 2 inch hose?
sassyotto
Paul
so it looks the same width all the way to the end so you would need to get a 1.5 inch adapter to 2 inch hose? Why would Butler do that? And at $950?
all the Butler wands have always been 1.5, even the 18" head version.
$950 because they are made in the US, very well I might add...
KevinD
Kevin Dumas
So when did they finally step up the 10" to 12"?
I think the (2) 10"s I have are from around 1988
