just for you 98%'rs
sassyotto
Paul
yah, Im having an issue with my Titan 575 only 3 years old. About once a week turn the key and you can hear everything work but it does not turn over. Run a long jumper cable to the van battery. Had this happen with my Prochem Apex (same Kubota engine) and we replaced the starter and that solved it. Thinking of doing the same on this one. (new TM battery did not solve it)
I was always told not to start the dead battery while the van engine is running
Was the transit running when you turned the key over on your 370?
I was told it puts a heavy pull on the alternator, causing early wear. I don’t know the facts. Just been advised from old mechanics
sassyotto
Paul
yah, that was in the Hydramaster Manual too. I keep forgetting. just gotta find the cause and get it fixed.
I replaced 8year old battery on my truck mount in December.
Headed to Wallymart before my two gigs tomorrow.
Spring cleaners are starting to wake
