help troubleshooting chem feed 370ss
Lyon
Chem feed quit drawing, only use liquid rinse, am original owner. no air bubbles in meter when priming, force water through feed tube with garden hose and didn't find any leaks, removed filter and it was clean, what next?
Swani
Mikey will probably be able to help you best, but I have a few follow up questions that may help us troubleshoot. What kind of Chem pump do have? Have you checked your diaphragm? Is there any cracks in your meter? Does it prime when you block the vac hose?
Replace your diaphragm and place the incoming and outgoing hoses into your GPH meter and make sure your hose clamps are nice and tight but have not perforated either end of the vinyl hoses..
Small brass leak beyond chemical pump
Reactions: Living The Dream
