probably the biggest benefit of going with VLM
If you hire people to do the cleaning, that is..
You can go down at least two levels in education in your workers.
It takes a certain mental capacity and mechanical ability to run a truckmount and wand/RE/Zipper.
Right from left, up from down, red from green, gravity, on/off, wet/dry, positive/negative so on and so forth are all needed skills to clean carpet with HWE.
So figure minimum of $18 and hour for this guy..
If a guy can push a lawn mower he can run a OP/CIMEX/CRB..
$12 an hour.
Right?
$12 an hour.
Right?
I am splitting a job with another competitor where we will be using the Phoenix and the Sprayborg. I figure 5 minutes or less training him on the Sprayborg.
Reactions: SamIam and Mikey P
$12 an hour.
Right?
you mean putting them with an experienced man/men in offices?
'cause the person you described won't have a driver's license and/or be some kind of dysfunctional fvk that can't pass an idiot test
They hired you though..
my wit, minty fresh breff and killer good looks
lta
