Any dealers here with a General TX1810 in stock?
Jim Williams
Jim Williams
Losing prime could just be an air leak somewhere. I would check that first before replacing the pump. You might end up replacing the pump and still have the same problem.
Thanks, I'll check that out. It just occurred to me that I do have a short piece of hose with a plug in it where the injection system used to be hooked that could be sucking air.
Alot of times you can find pumps cheaper at a pressure washer site.
But they probably come with different seals.
Reactions: Jim Williams
