Did a lot of encap this week
Meter Maid
The Undetective
Dayton,Ohio
I’ve only pulled the hoses a few times since getting the Odyssey.
Not only is it easier, the carpet looks better. I had another long-time customer last week text and ask me what I did different on her last cleaning.
Reactions: Mikey P and Nomad74
Anybody tell you the earth isn’t flat after all and eggs don’t cause heart disease after all?
Funny how things change.
correct me if I'm wrong, Five-O
but you started as a flat earther (padder) then got a TM and told everyone the earth was round and flat earters (padders) were hacks, and now you're a flat earher again?
all due to 1/8" more orbit and MF?
is that it?
is that it?
None of his past pos OP machines had the head weight of the Oddessy
and PCP/ TOPSSPOT kicks ass.
Meter Maid
The Undetective
Dayton,Ohio
is that it?
I came from Orbots and Mytee.
They didn’t pull dirty water like this one.
My truckmount isn’t going anywhere.
AlienAgent
Ohio
Joe Gingerich
If someone truck mounted 1000ft2, then dried down the wastewater and weighed the dried soil. Then compared that to the weight of soil pad extracted by an OP machine into a microfiber in the same square footage side by side, what would the difference in weight of soil extracted be?
We may find that the pad wiped as much from the fibers as the traditional extraction does, in many instances. Trashed carpet and industrial settings would likely favor the truck mount obviously.
Depends on the type and amount of pads used.
Reactions: AlienAgent
Meter Maid
The Undetective
Dayton,Ohio
You would also have to factor in how much encapsulated soil is removed during subsequent vacuuming.
