- Oct 6, 2006
- 116,676
Tiles popped loose an hour ofter getting "spinner'd"
Florida.
Concrete subfloor..
Look at the clues
which is most likely hiding the fact that the installers left no room for expansion.I blame the quarter round.
“As a consequences”
I question their cleaning conclusion since they’re too ignorant to properly use the English language.
“As a consequences”
But not the other 20 odd. Marty rules OKNot to pique your ire Marty....
I caught the "as consequences" too
Yeah I mentioned probably not enough thin set, but I hear hallow points in tile all the time and it's doesn't pop up, I just see breaks before I touch it.Always an installation failure. Nothing to do with the cleaner
It certainly an "issue" for the customer when it happens one hour after it was cleanedagreed with cleanworks. not a cleaning issue.
I think it’s just bad timing for the cleaner. It was ready to pop anytimeIt certainly an "issue" for the customer when it happens one hour after it was cleaned
Tenting is due to incorrect installation but as in the case of this particular photo it was aggravated and definitely the straw that broke the camel's back but had the concrete subfloor not been wet. Most likely there would have been no tentingOne of my many fears with tile cleaning.. Golf ball test or even the seam tractor going over it to hear if it's hallow.. A lot of WDR guys have had problems with "tenting/popped" tiles after drying out..
I'm sure your BHGG are the answer to this problem.. Lower pressure and heat used to clean it..
Golf ball test? Drop it a few inches and listen?One of my many fears with tile cleaning.. Golf ball test or even the seam tractor going over it to hear if it's hallow.. A lot of WDR guys have had problems with "tenting/popped" tiles after drying out..
I like puzzles.What a bunch of PussTards. Just stomp it down with your foot.
correct..orangish red stains. More orangish almost like a dull brick color.Golf ball testing is if it sounds hallow by bouncing the ball.. Seam tractor with spikes attached to a broom handle and you roll it over the tiles, it'll sound hallow as well.. A well installed floor won't have the hallow sound..
My pops has been a certified inspector, so I've seen some sh!t jobs.. Imho you couldn't pay me enough to deal with people's BS when it comes to finger point
As for Down feathers, it had the orangish/red stains? We call those humidity stains and you can only treat it but it will come back.. Real PITA to deal with.. Some customers we've done with sewing a bag of canvas around the cushion on the inside.. Most don't want to pay for it.. We advise with our humidity/tropical weather we have, it's inevitable..
But yes, dry foam would lessen the chances of more issues.. I hate working for free as well, unless it's for a good cause..![]()
yea, my guys new it was crunchy and still cleaned it, i bought that floor....It certainly an "issue" for the customer when it happens one hour after it was cleaned
I mentioned that in the Facebook thread, not a enough thin set used, but someone mentioned it was improper application and installation of thin set and tile.Golf ball testing is if it sounds hallow by bouncing the ball.. Seam tractor with spikes attached to a broom handle and you roll it over the tiles, it'll sound hallow as well.. A well installed floor won't have the hallow sound..
My pops has been a certified inspector, so I've seen some sh!t jobs.. Imho you couldn't pay me enough to deal with people's BS when it comes to finger pointing..
CrakyWhat a bunch of PussTards. Just stomp it down with your foot.
