I ve dropped fans in the middle of summer and had carpet dries to the touch in an hour.
My pc ti was 12 flow, my slot devastator 8 flow.
So there maybe a little more recovery with a holed glide.
Doesn't count
All opinions must be factually backed with a BD Delmhorst with batteries no less than 6 hours old, 2100 moisture meter with pins inserted through fibers, backing, pad and 1/16" of subfloor in 19 random locations per every square foot of test carpet.
I left 3 fans on a piss job senior group home.I use to leave fans here, IF they agreed to bring them to my house when ( they think) its dry.
9 out of 10 times the fans came back the same day.
I dont bother anymore.
I found that people confuse cold carpet with wet carpet. So now I tell them to not cornfuse the two.
instead of telling us you're greatest, most knowledgeable spiritual person in the history of the world, and anyone that disagrees don't know sh1t
Put your fingertips into the carpet and not rely on the palm or back of hand test..
What prespray is best?….? How heavy did you pre-spray..
Even Frank Perez in CA with his PowerClean Genesis unit did an emulsifier only cleaning @600psi with 240-260degree temps and bone dry in 15mins doing the pants kneeling test.. While it was eye opening for me, you could smell the Neptune hose breaking down..
So let’s get this thread back on track and did Matt ever fix his “banana glide” on his new wand?
He boiled it in a round pan. Everyone knows you're supposed to boil your glide s in banana boat.
You're welcome for me sending you that awesome picture in our text conversation that i was trying to have with you, sending you compliments as well, the day you were a brat dick, playing in your sandboxPerfection... View attachment 122184
I fixed it last night. I put the matter in my own hands, discovered the outside internal slots were too far out to the edge (keep in mind, this head is only 11.5"), which caused the curve when you pushed it in to fit it. So I cut those out and it now sits perfectly aligned with the lips straight, not curved.
You're welcome for me sending you that awesome picture in our text conversation that i was trying to have with you the day you were a brat dick, playing in your sandbox
So since this was your old design that you didn't make Mike, it might be good to take a look at one you have and experiment with it and see how much better it fits with those two outside inserts cut out. But what do I know? I've got work to do.
The curve was created by you inserting it UNEVENLY.ok.
Go back and look at the picture which showed the curve.
Do you realize you’re wasting your time?I put the glide on, the same way Trip did in his video on his thread. This isn't rocket science.
Concerning the generous discount you volunteered to me on that wand which I thanked you for, I thought you were looking for feedback in return, which is why I took the time and sent the detailed, accurate pictures and positive feedback with the other concerns, which you were not at all willing to accept.
Leaking is not good on a glide. You need all the suction coming from the slots for maximum water recovery, unless you're cleaning a hard surface (the purpose of the brushes on your hard surface glide) to prevent real lockdown.
I've used both methods and no air leak is better.
yesDo you realize you’re wasting your time?
No Matt, I gave you $150 off to thank you for your activity here.thought you were looking for feedback in return,
Can you give me two examples of that?he likes to take credit for shit he doesn't do,
you recommended the fking bonzer which was entirely inaccurate on that POS
Trip is using a SSTI14, which a baby could plug a glide into. IncomparableI put the glide on, the same way Trip did in his video on his thread
You're wrong. Leaks assist lift.Leaking is not good on a glide. You need all the suction coming from the slots for maximum water recovery,
due to the triangle head and his #148 lanky pounds and the Goop he shouldn't have installed, we'll have to hope all his mobile homes have a slight subfloor curvature to them .It's not a bug. It's a feature!!!!!!!
