Auction includes:
Saiger’s Sauce Code Red features the same great formula of original Saiger’s Sauce 1 plus an added oxidizer and enzyme to power through the toughest, greasiest, grimiest soils you can find.
Stable Oxy and Enzyme Combination Code Red relies on a high-performing oxidizer plus a fast-acting protein enzyme to digest oily deposits and organic soils. It breaks down thick, sticky binders that hold onto dirt and soiling, emulsifying them for easy rinsing. With other enzyme-based formulations, the addition of an oxidizer and heat will destroy the enzymes and render the product ineffective. But Code Red’s enzyme is not sensitive to heat or harmed by oxy, allowing you to get the power of both agents in a single formula. Code Red was designed for cold water efficiency and effectiveness, so it's great for smaller truck mounts and portables. (Though it performs well and works even faster with heat!)
Note: Once mixed, Code Red doesn't have as long of a shelf life as other Saiger's Sauce products. We recommend using up your mixed batch the same day for best results.
Your Go-To Product for the Toughest Carpet Cleaning Jobs Code Red was designed specifically to tackle the worst of the worst—trashed rental carpets, severely neglected residential carpet, and greasy, grimy restaurants. You’ll love how Code Red performs in the main eating area of a restaurant, but where it really shines is on that first bit of carpet right outside the kitchen. You know the part we’re talking about—that small section that absorbs most of the grease and oil from the bottoms of the wait staff’s shoes as they exit the kitchen. The area with black grease so thick, you could scrape it up with a business card. Code Red goes to work right away, liquefying those thick, gunky deposits for easy and thorough removal. It rinses freely and won't leave behind any sticky residues. You’ll be amazed at the results—and your customer will be thrilled!
Fragrance-Free so You Can Add Your Favorite Deodorizer Code Red contains no perfumes or added fragrances, making it a great product to use around individuals who may be sensitive to strong scents. And since it is completely fragrance-free, you can add in your favorite deodorizer and leave your customer with clean carpet that smells great, too.
No Harsh Additives. Saiger’s Sauce Code Red is free of harsh additives that can irritate users and building occupants.
Code Red contains ZERO of the following: Butyls, D-limonene, NTA, Solvents, Fragrance
Developed by Saiger's Steam Clean, a family owned and operated cleaning company employing four generations of cleaning specialists, Saiger's Sauce Code Red is the newest product in Saiger’s line of high-quality carpet cleaning technology.
“Take your cleaning out of the Ice Ages”. Saiger's 10 Below was a 3-year project to create the perfect, safer cleaning formula that packs a punch for cleaning carpets, tile and grout, and upholstery (not recommended for fine fabric upholstery). If it's good enough to clean in freezing cold climates, it's good enough to clean anywhere. Working through relentless field testing, 10 Below emerged with incredible cleaning power! Take your cleaning to the next level with the newest, safer cleaning agent! You and your customers will also be pleasantly surprised by how it eliminates odors. You don't have time for your pre-spray not to work, so use 10 Below. It works.
Features and Benefits:
Odor elimination with the power of peroxide and a true odor destroyer! A unique high-powered Peroxide formula with a true Odor Destroyer! This is not a masking agent. This product will go after the urine and odor-causing organic stains! Get quick results for your customers with this fact-acting product! OdorOxy is designed for cleaners who don't have the time to wait for enzyme activation.
OdorOxy Urine & Odor Stain Destroyer is a unique formula that eliminates unpleasant stains and odors in carpet, upholstery, fabrics, and hard surfaces. The Odor & Stain elimination oxidizers will remove organic stains & odor from urine, blood, coffee, vomit, and much more. Avoid using on Wool and Silk materials, and be cautious with natural fibers.
USAGE
Directions: Saturate the areas of concern to reach the odor source and the stain(s). Light agitation will help to assist with stain removal. Apply before cleaning and OdorOxy can be applied in more serious areas of concern after cleaning. Let air dry. For light stains and odor, you can dilute 2 parts OdorOxy with 1-part water. Following same application procedures.
View: https://youtu.be/pPvkycfL8rI
Total retail value $319.47
Free Shipping to lower 48
Starting bid $190
Minimum bid increment $2
Auction ends Wednesday August 9th at 9PM EST/ 6PM PST
- Two 6.5 pound tubs of Saiger's Code Red Pre-Spray $107.18 value
- Two 6.5 pound tubs of Saiger's 10 Below Pre-Spray $92.34 value
- One 4 x 1 gallon case Saiger's OdorOxy $119.95 value
- 9.5 pH
- Carpet Warranty safe formula, including stain-resistant carpets
- Unscented; no odor present while in use except a pleasing, fresh scent
- Odor Eliminating Formula with no perfumes or scents
- Cleaning power that gives high-pH pre-sprays a run for their money
- No Butyls, no d-limonene, no Solvents, no NTA's
- Safer chemistry with true cleaning power
- Eliminates stains and odors
- Powerful oxidizers
- A true Odor Destroyer
- pH: 5.0 - 7.0
- For use on carpet, upholstery, fabrics, and hard surfaces
USAGE
Starting bid $190
