This is a great perspective Nate, thank you. I'm feeling more positive now after I laid down and took a nap. My mind was just overwhelmed.Is your name Matt?
While it wasn't fun living through your morning, everything happens for a reason.. You wouldn't have found out the heat went out to the shop if you found the tire chuck.. Count ya blessings Swani! I know the feeling all too well..
If it wasn't for bad luck or hard luck, I'd have no luck!
Windchill will only effect you. Not your equipment.I dont mind cleaning in cold weather, but next week each day has wind chills of -20 so when its that cold it could affect the TM. Thats a risk I cant afford to take.
I called every job next week and they all totally understood and rescheduled.
View attachment 125797View attachment 125798
Will you share the diesel heater? Where to buy and how much?I have a Chinese diesel heater in there and I could keep it 60° in there no problem anytime of the year
I have it in my enclosed trailer. I'm going to probably put one in my van.You keep it in or out the van?
Forgot your skates?- 28 this morning. I was going to the rink for a skate, but...
It's practically balmy here compared to that! It was only -6 at my house this morning!- 28 this morning. I was going to the rink for a skate, but...
My balls fell off.Forgot your skates?
I see there are several options now. Especially on the TikTok Shop for around $100 dollars. I purchased mine through Amazon. The only upgrade I would do is try to make it to draw off a 5 gallon jig.
That's good to know. I'm actually looking at this Webasto for my Promaster that runs on gas. I wasn't to sure about them, but I've been reading tons of good reviews......But maybe the guys that had bad reviews blew up?You need to change to the nylon fuel line as well.. That green line has caused fires..
Hcalory is the better brand of those Chinese Diesel Heater..
Webasto Air Top 2000 STC Gasoline 12V Ram ProMaster Kit with SmarTemp 3.0 BT controller
The Webasto Air Top 2000 STC gasoline heater is one of few 2KW petrol heaters on the market, a blessing for those of us who drive a petrol Ram Promaster.www.heatso.com
Working in the cold Michigan weather forced me to concock a fold out tent at my truck door. Toasty!!!yo….i must be a Prima Donna canceling at 32° or less.
Working in -20°? Is this a typo?
no way for me.
Bob! Welcome back!
How’s the wife?
well, I have to weigh what is the possibility of something freezing and needing repairs (downtime) vs the income for the day.Windchill will only effect you. Not your equipment.
Remember back ....how you HATED those stupid old people wit all the stupid little plastic O2 hoses.....all overBob! Welcome back!
How’s the wife?
Funny....Looking back, I can only remember one old person whom I didn’t like. Even with her I was respectful. I recognized the source of her meanness. I’m glad because I now endure some of what affected her. As for you, you’re probably only now receiving what you have earned. May she torment you many days.
I feel your pain; everything slows down at temperatures below zero. I had only four jobs at 0 ° last week, all under 100 feet. My solution hoses are thermoplastic, 120 and 150 feet long, so no QDs lying on the ground. I connect the hose after the engine runs for a while, and the heat is sufficient ( only a few minutes ), and I run inside and start spraying. It indeed takes only a minute or less for freezing to take place. In temps well below zero, it is better to run on lower heat because hot QD on the machine will also freeze along with a bleeder hose.A week ago a customer called and needed their home cleaned that they were selling. They were in the process of moving and wanted to wait until closer to the closing date to have it cleaned. They were supposed to have everything moved. Today roles around and it's -20°F and nothing is moved, they didn't want to move the cleaning date because of closing, so I explained that I needed to have a clear path and would need to get in and keep the water moving to prevent freeze-up.
Well, I got there, and nothing was moved; they want me to clean 4 area rugs that were never discussed. They needed help moving stuff, blah blah blah, and then my machine froze up, and I ripped my sliding door handle off my Promaster.
Not a good day!
Water extraction during freezing temps is worse than HWE cleaning.A few days ago, a long-time customer called and asked for water removal after a burst pipe caused havoc in his gym. I asked two questions: 1. Is the source of the problem fixed?
The answer was Yes
2. How many square feet were affected, and is the carpet sloshy when you walk on it?
Both answers end up being a lie. Go figure...
Last winter, it happened just that. I had to clean two sectionals, and with less water moving, the vacuum hose became a snow coneWater extraction during freezing temps is worse than HWE cleaning.
The water will freeze up in the vac hose, and if the water in your transfer pump isn't flowing, it freezes as well
