- Feb 4, 2016
- 14,637
- Name
- Matt w.
One of 2situations in the 80s:I believe at one time the original Prochem company did that, though it could have been our original service manager would do it before we installed a machine.
Back in the late 80s Prochem made a single jet wand that would shriek when the vacuum was engaged. We had to “tune” it by taking a screw driver and bending the vac opening a bit to quiet it.
Butler stagger sthem much moreStagger their jets so we don’t have to angle the spray.
Looks like the “other” wand companies are kinda lazy because my PR TI and other pmf wands never had this
Why doesn't legend do that? Or do they still use pmf to produce their wands? From your pictures of all the goobers that send you pictures of their jacked up wands, you could easily send the big box company your concerns for the price they want for their wands.Butler stagger sthem much more
Yes PMF makes them.Why doesn't legend do that? Or do they still use pmf to produce their wands? From your pictures of all the goobers that send you pictures of their jacked up wands, you could easily send the big box company your concerns for the price they want for their wands.
ok ok, I can't argue with you on OP padding. My experience on LMC is very little (175 and cimex only), but even those two were a joke. And I've read some of the hardcore OP guys say they can do a good job with a 175, which is very questionable.No he's not.
Proper padding provides great long lasting results.
This cold hard fact has nothing to do with what how other methods can go wrong.
Both of you are speculating, sadly.
So, when you say this, #Iassume this is residential cleaning?ok ok, I can't argue with you on OP padding. My experience on LMC is very little (175 and cimex only), but even those two were a joke. And I've read some of the hardcore OP guys say they can do a good job with a 175, which is very questionable.
My results are too good with HWE to switch over. If I ever do add LMC to carpet, it'll be with a CRB for the reason that it'll never void a warranty. And with these big jobs that require a description of how the cleaning will be done, that's a big deal for they mention it in the request for bidding
I know you're a cimexer. I never had good results from mine.So, when you say this, #Iassume this is residential cleaning?
For the 39 minutes you used it?I know you're a cimexer. I never had good results from mine.
I gave it 3 strikesFor the 39 minutes you used it?
For these 11’x12’ rooms, there was a 2min loss in time with the 11” vs the 14”Yes PMF makes them.
They are not open to feed back, and due to costs and function, for every PMF wand I move, I sell 20+ Westpaks
Do me a favor time yourself cleaning 200 ft of open space with that 4 jet and then do 200 ft with the 530 at the same moving pace and let me know what the difference is time
Cleaned at a pressure of 500-550 and never got a difference in dry time. I think the 4jet might’ve cleaned a little betterAny visual or dry time differences of note?
And proper wanding provide greater, longer lasting resultsNo he's not.
I still challenge any carpet buffer to my cleaning technique that Ive perfected with HWE. And I know I'm not the only one. But I know that you pansies will weasel your way out of a friendly competition on real dirty carpet. Not a clean, new carpet like the one you introduced that phoenix on at your first hard surface cleaning class back in NC. I still wonder why you were pushing that carpet buffer in that class where people were there to learn how to polish natural stone.
The only way padding can be better is if it's competing against a portable trying to HWE at only 200psi 2flow at a location where a tm doesn't have access.
yeah, I'm in the mood to be a jerk this morning. Happy Monday douchebags
I think it was your hard surface class before you re-worded to multiple surface at a hard surface facility that hosted the class.There's a difference between being a jerk, and being stoopid, and rude.
Matt, what was the name of that class?
and what are the 6 topics we discuss?
