- Oct 6, 2006
- 117,121
I hear from some portable owners that that wand works fine, I'll assume they have the 6.7 vacs in themLimited vac power over here. If the brush raises it off of the floor and doesn't wrap all the way around the glide, would a porty chump like me lose a significant amount of suction while using it?
My PEX 500 mentioned in the brochure only has 5.7 vacs in it. Scrawny guys like me have a hard time pulling 130lb monsters up staircases, then again maybe it would toughen me up a bit for the next time Fred picks on me.I hear from some portable owners that that wand works fine, I'll assume they have the 6.7 vacs in them
Didn't you get a brush glide for the Evo?My PEX 500 mentioned in the brochure only has 5.7 vacs in it. Scrawny guys like me have a hard time pulling 130lb monsters up staircases, then again maybe it would toughen me up a bit for the next time Fred picks on me.
No I got a brushless hole glide for the Evo.
That wand is actually pretty good.Well good, that might make that wand good for something.
Not with a real glide.Lotta chatter!
Maybe we'll have some more debates in a few years after I get a more manly portable and pull it up a few thousand flights of stairsYou better get two
I wasn’t picking on you though…
VLM is the answer.Maybe we'll have some more debates in a few years after I get a more manly portable and pull it up a few thousand flights of stairs
I suppose for now I can just fill the solution tank before hauling it up to Mrs. Jones 3rd floor apartment![]()
Man be careful going down stairs with the PEX with water. It’s really easy to tilt forward and get off balance even with 2 people, much less 1. We’ve done it and it’s not pretty.Maybe we'll have some more debates in a few years after I get a more manly portable and pull it up a few thousand flights of stairs
