- Oct 6, 2006
- 117,079
Are you suppose to dilute it?I hope not. SaigerCide is the best deodorizer on the market. The customers absolutely love it. It didn't take me long to blast through that 55 gallon drum I bought.
I normally dilute 4-8oz per gallon depending on how dirty the piss-hole is that I'm cleaning. If it's real bad I'll pour 4 cups in my acid rinse as well.Are you suppose to dilute it?
You'll find that the Matrix Breakdown formula is unique in that it can be rinsed with water vs most non-voltaile solvents like POGs requiring a detergent or voltaitle solvent to remove the residues POG will leave behind. Many have reached out over the past few weeks and have been pleased to hear the breakdown formula is sticking around!
thank you for posting this!You'll find that the Matrix Breakdown formula is unique in that it can be rinsed with water vs most non-voltaile solvents like POGs requiring a detergent or voltaitle solvent to remove the residues POG will leave behind. Many have reached out over the past few weeks and have been pleased to hear the breakdown formula is sticking around!
Blast P.O.G.
*Compare to Matrix Break Down P.O.G. For oil-based stains that refuse to budge, try MasterBlend Blast POG. Blast works quickly to remove grease, paint, tar, even lipstick, and can be rinsed out easily with water or MasterBlend Citrus-Sol MX Spotter. Treated areas dry fast to save you time Not...masterblend.net
that's CTIAre they the ones that made molecular modifier?
Is pros choice and CTI the same? I ask because i buy molecular modifier and odor Eliminator under the pros choice brand namethat's CTI
CTI, the manufacturer of Pro's Choice Products, has over 120 Distributors throughout the US and Internationally to provide cleaning and restoration ...Is pros choice and CTI the same? I ask because i buy molecular modifier and odor Eliminator under the pros choice brand name
Pros Choice OSR, The King of odor Elimination!I will have to say my favorite of all their odor control products Pros Choice X-cide odor remover is one of my all time favorites
Ive become a big fan of odorcide fresh scent.Pros Choice OSR, The King of odor Elimination!
Yes those are great products!Ive become a big fan of odorcide fresh scent.
Molecular modifier is best for cat pee imo.
It does have to be mixed properly. I use to use it a lot.Yes those are great products!
I fine that OSR ,use properly has worked the BEST for me .
Mixed properly, that's a must!It does have to be mixed properly. I use to use it a lot.
