here is something new to (speed) dry carpets after HWE cleaning
https://www.carpetcruzer.com/
Procedure​
How Carpet Cleaning Has Changed Over the Years
1907
Portable Cleaning
Invented Mid 1907
Still used 117 years later
Results
  • Not very clean
  • Not very dry
  • A lot of work
Late 1960s
Truck Mounts
  • Introduced in late 60s
  • Most popular in the 1980s to present
Best Pro Method for past 60+ years
Results
  • Better Cleaning
  • Dryer than portable
  • Less work
  • More water pressure
  • Heat
  • Deeper clean
Early 1980s
Rotary Cleaning
  • Restore carpets with deeper cleaning with 450 agitations per minute versus 40 with wand per minute and more extraction
  • Carpets are left cleaner and dryer than wands & portable cleaning
More Heat + More Agitation = More Referrals
Now
For the Professional Cleaner
Challenger Carpet Cruzer
The wait is over, now you can dry carpets after steam cleaning. After 40 years with no real industry equipment built, The new surface-to-surface drying system is here.
Yes! You can dry stairs & carpet and solve customers’ concern for wet carpet and get paid for it.
That’s a pretty cool invention. So it’s a hot hair blowing machine over the surface??? Is that correct?
That’d be a pretty cool upsell
Dwain Ray
Ill stick with my good ole tried and true drag wand to rinse and if it needs to be dried more ill make an extra drying pass ( as i do on all wool carpets). What happens if you park that "giant hairdryer " on the carpet? Will it get hot enough to do damage?
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
No need to worry it is thermostats to kick off to low heat
Also eliminates the spin with customers not getting true value for topical products ie Re protecting causing over wetting and min protection because of the fear of over wetting
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
probably leaves corn rows behind...
Not really it lifts pile up and dries restyles with out leaving ugly rake lines also when you walk on wet damp carpet you crush the fiber down and it stays down till u rewet just like if you sleep on wet /damp hair it stays down till in the shape it dries till re wet thx joe
I was kidding, have you ever shown this to anyone?
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
This is like tv infomercials. Cut to the chase, how much???
It’s on the website at carpet cruzer.com as Iam Canadian it’s in cnd dollars 6000.00 and you can earn 20 /25 per sq ft not sure of your USA sq ft charge but I earned 40 cents per ft rx20 20 cents per ft and on small job living room hall and stairs 25cents per ft85 cents per ft while my fellow cleaner were having to do 4/5 jobs a day today make what I did on 2 jobs and solving the old age industry problem the customer asking how long does it take to dry my answer it’s dry when I leave the house hope this helps thx joe
Dwain Ray
Thank you, i think for that kinda money ill stick with the voodoo i do clean n dry with rx20 then rinse n dry with weighted drag wand .50 or.55 persqft .55 or .60 with extra dry pass with drag wand. No cords no power no problems clean, residue free, dry enough
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
You can’t deny the better cleaning with rx20 or other rotary equipment but most would agree that you need to be paid more for the service I can old equate in Canadian dollars a truck mount here cost 70000.00 for 40 cents per ft plus a rx20 6000 and you may get 15/20 cents extra and this cost cnd 6000 and you can get 25/ plus per ft and mor Re protecting jobs and I could take this eq and just offer cleaning and re protecting and make as much with out the overhead of truck mounts considering also rainy days longer dry times for me when I started cleaning back in 76 and when the trucks came on the seen I moved on why because nobody else had one and the same with rx20 in early 80s moved on it also and came to realize I could offer something that nobody else has drying I viewed it like this as the first person said at the chat it’s a good thing for up sale like Mac not having gravy they can’t offer it thx
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
Is this device for real like I don’t get it
Yes it is you buy a clothes dryer to dry clothes your wife buys a hair dryer to dry her hair you go through a carwash and a big fan blow dries your car in restoration you buy dehumidifiers and fans to dry pad carpets drywall all thing we do or have done for convenience conclusion dry carpets then to solve the customers concern after she /he asks price then next question is how long does it take to dry carpets I have a big blower not long I double and triple wand so not long etc etc or dry when we leave hope this helps you to get it thx
Mr Brightside
Southern Cali
Jay Wags
I don’t get the need for the new equipment
Is the tool completely separate from cleaning so I would do my normal routine then use this device?
My carpets dry fast during warm months but basements during the winter have been more of a challenge but more dry stokes less psi less flow and run the Everest on high gets it done
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
The tool complements the cleaning first then finishes the job so the customer won’t slip on areas when there feet socks area wet and they can use as normal and go through there normal as it is top down drying there is no wicking issues and it will pay for it self over time when you take into account the less fuel brakes tires and your self trying to do your daily quota you will pick up extra work with out wearing your self trying out on the web site there is 3 bars at top right on first page push those and look at what you can make plus as you change what you think your worth this is only a guide the smaller the area the more I changed I never did package pricing always sq ft hope this answers your question thx
Jh16
Alberta
Joe Rorke
Years of Experience
50
Role
Business Owner
Any videos of it in action?
Not yet because it rides on a cushion of air you can guide it with 1 hand and when first built one my 8 year old son could guide it and a wife could easily run it if your are a team it’s 45 lbs and 20 lbs of cord to power it
Latest Auctions
