Hydro Force sprayer,
steamron
Northeastern PA
Ron
It seems that my Hydroforce sprayer is not really putting out enough chemical.
I went the route of 4 to 1, when I first got it.
I checked the small filter it's clean, and I can see the foam from the prespray on the carpet, it just that I can go a few weeks without refilling the container when I use to fill it every couple days.
I figured something is clogged somewhere.
Can anyone help?
Thanks
they live
Michigan
Steve
I often use 2 jugs a job at 4to1. One jug on smaller jobs. I lay it down heavy.
You can get a repair kit for about $35 but I woukd buy a new one if i had it awhile.
Dwain Ray
Can anyone help?
Thanks
You said you checked the small filter?? The hydraforce has 3 by my account. 1 inside the jug at the end of the pickup tube 1 at the quick connect inside the handle and possibly 1 at the spray tip especially if you have a tee jet it'll have a ball check strainer (looks like the one in the handle but has a sping loaded check valve to stop drips) also can have a ball check strainer screwed into the back of a vee jet but i don't think that comes standard from hydraforce so when you said you checked the small filter which one? Do you have a real hydroforce or a cheap Chinese knock off?
Reactions: Matt Middleton
icleancarpetz
Rafael Samson
After monkeying around with mine on and off problems, buying parts and dealing with jerk chicken vendors….i decided to go the route of 5 gallon sprayer with wheels.
I pimped it out by changing the pump to higher psi, changed the wand to hydroforce pump up sprayer i had laying around, installed a more flexible hose. Changed the tip. Easier mobility.
Never looked back.
Works for me.
Reactions: Bryce C
That hose that's attached to the barb inside the HF dries and gets stiff, which will start to pull air up in the hose, causing less pull. Put a fresh hose on it and see how it works. If it still doesn't pull any chemicals, just replace the dema
they live
Michigan
Steve
Yeah i need to replace mine again. It starts sucking air at the barb. Ive had to flip mine upside down to get it to draw in the past. Its an easy way to check it.
He could be mixing the prespray to thick also. I only add 3 scoops to a gallon and use soft water. It lasts so much longer now. Ive been trouble free for about 6 or 7 years with this one other than the feed tube drying out and cracking. It only lasts a couple years.
DrUmM@sT3r
Bishop, CA
Mark Medora
I drilled out the yellow plastic metering valve larger, but still not refilling the jug for weeks. I need to check the o-ring, but I did lightly stretch the spring and the ball moves fine, just not pulling the product. So I just removed the yellow metering valve after my last job, we'll see if that changes things. You told me on my last Hydroforce, to remove the yellow metering valve and use 4 scoops and that produced great results. TY 👍🙂
Mr Brightside
Southern Cali
Jay Wags
Honestly I love hate the hydro sprayers too expensive and I can’t seem to keep them in service for a long time
But
They are super convenient and seem to have the monopoly
Dwain Ray
Is the secret using liquid detergents?
I disagree, i keep 3 hydroforces on my van and all i do is change the hose and wand(it connects thru hollowed out ¼ quick connects) 2 are for presprays 1 for odor control products. I only use powdered presprays and liquid odor products and they all seem to wear the same. Ive found the biggest problems have beem when using non hydroforce brand dema valves even the wanders stainless ones are problematic (i bought 5 only 3 worked good outa the box and only 2 are still in service. About to test his repair for life policy) so in short hydroforce brand good Chinese knockoffs not so good
Reactions: hogjowl
But
I have very few problems with mine. I have them all at 4-1. I use a lot of powdered products but I mix them in a pail with hot water and stir well before pouring them into the sprayer. Periodically, I flush them out with a non detergent acid like Ultra Chem Labs neutralizer.
