Bryce C
DFW
 - Feb 9, 2024
 - 1,199
- Name
 - Bryce
if you had a truckmount in New England but no garage to store it in over the winter? I am considering renting a climate controlled storage unit for December through March and just shutting it down and reverting to my portable and trailer setup those months. Then using a small heater and wireless temp monitor in November and April but still using the truckmount those months since the ground isn't frozen and I can still dump recovery water.
I could run some windshield washer fluid through the system and keep it in my driveway covered with a small space heater inside and a Marcell wireless temp monitor to prevent any issues if the heater fails from November through March. From what I understand even winterizing it with windshield washer fluid shouldn't be considered good enough, there is still water in between fitting threads and other places that should still avoid freezing temps if possible. If it is in my driveway I could uncover it and run it occassionally to stretch her legs and keep things moving on warm days...
Running it on jobs mid-winter seems out of the question even if I get climate controlled storage close by because I have no where to dump when the ground is frozen. I need a heated garage with a drain built into it to do that I think. Unless I find a car wash close to the climate controlled storage... And I'm at least a year or two away from buying a home and setting that up. What do you guys think? What would you do?
