A nifty electric sprayer for those who like to say "Viton"
I've used this twice now to pre-spray before running my PHX..
What a joy!
Can't think of a single thing I would change about it
Even the price is great
MarkieMark
Mark Franco
Electric sprayers are awesome when you find the right one 😉. Extra battery in the trucks too, though they last about a week with a full schedule. You can also cut the cheaper wands off and put a nice spray gun with some barb to 1/4npt connectors.
Couple of mistakes can kill them......warm water only, mix well, turn off after each use.
Reactions: jessi
I have one and it's great for spraying stairs when using the oreck. It's only 20 psi and very low flow. Not really enough to spray rooms unless you have a lot of patience. Reliable so far. Mine is two years old.
What tip are you using?, I didn't have any problem putting shampoo down but I'm not using it to hose down hot water extraction pre-spray..
I modified it to an 8004 T jet.
I wouldn't look at this as a replacement for the hydro Force where you want to lay down serious pre-spray but rather for what I was using it for and light application of an encap or possibly upholstery free spray or deodorizers or oxidizers...
Dwain Ray
I prefer my stainless sprayer with a 45.00 rechargeable air compressor. Ive been using it for 3 years now and the only problem ive had was i had to unclog the hose connection where the compressor connects to the Schrader valve. But i only use it for upholstery cleaning. I use hydroforce sprayers for presprays and odor control products
I find it perfect for stairs and the Oreck. I use it in the shop as well for deodorizers. Pretty decent sprayer. Could put an 01 jet and it would be great for upholstery.
MarkieMark
Mark Franco
These put out 115 PSI, adjustable of course. I prefer the 2.5 gallon ones at 60PSI. Price doubled this year as they used to be $200 with battery.
Dwain Ray
I got less than that in mine and can inflate my Van's tire with it in a pinch also
they live
Steve
On the pumpup side all i did is connect a rechargeable air compressor to an already existing Schrader valve
Didn't you complain about holding/swinging a 1 gallon super soaker?
Just giving you a hard time Dwain.
I started using the other one of mine and realized why it was on tge shelf too. It must be 8 to 1. Took for ever to prespray my job this morning.
