Bryce C
DFW
- Feb 9, 2024
- 1,051
- Name
- Bryce
Have some of you used both types of battery powered multisprayers? There is the classic one which has a large 12 volt battery inside it and its own charging device, so you just plug it into a 120 volt outlet overnight. It is quite heavy though, but self contained. Then there is the newer model which takes power tool style battery packs which clip onto the unit. It is much lighter, but they have less of a charge so you probably need to carry several battery packs with you. However the multisprayer can stay on the truck and one only needs to bring the small battery packs in each night to charge them. For those that use them, which multisprayer have you found is the most practical overall? I have a classic model with the large internal battery, been using it for about 18 months and it hasn't skipped a beat. I purge it with clean water and charge it every day.
