- Feb 4, 2016
- 14,646
- Name
- Matt w.
You could try a little non volatile solvent. Mix it up well and see if it thins.Bridge point gel break. It sat on my shelf for a long time and now it’s too thick to emulsify the adhesive.
What evaporated out that I can add back in or is it ruined?
Maybe try a product such as prochem citrus pro. Or maybe goo gone??? Personally id toss it and go for a product that's mor resistant to drying out such as prochem citrus gel. Ive never had a bottle of this dry outBridge point gel break. It sat on my shelf for a long time and now it’s too thick to emulsify the adhesive.
You probably work tuff spots more then once a yearMaybe try a product such as prochem citrus pro. Or maybe goo gone??? Personally id toss it and go for a product that's mor resistant to drying out such as prochem citrus gel. Ive never had a bottle of this dry out
Quart bottle lasts between 2 and 3 years on my truck. Ive had other stuff dry up in the past . Pros choice is a product that comes to mind but not the prochem stays a white creamYou probably work tuff spots more then once a year
DOAH
Rubbing alcohol?You could try a little non volatile solvent. Mix it up well and see if it thins.
Rubbing alcohol is a great solvent by itself.Rubbing alcohol?
