Hot or cold water on human urine extraction?
Axel70
Russ Wooten
Role
Cleaning Professional
Years of Experience
20
I have an older gentleman client that is incontinent and there are some places throughout his apartment where he has had accidents. I normally use HWE and Waterclaw on these spots with some Unchained. It works ok but I do see some people claiming cold water is better than hot on urine. Do any of you guys use cold water or know of any better methods?
If the urine is relatively fresh, you could can use cool or lukewarm water.
If you are using Unchained or other peroxide based treatments, very high temperatures could cause color loss when they react with the product. This is also possible with sodium chlorate based solutions (often called "chlorine dioxide").
You are at the most risk with wool (pretty unlikely in an apartment) or nylon (more likely if the carpet is old).
I'm pretty sure that odor is more of a concern at this point than dyefastness. Are you being payed by the landlord or by the tenant?
Axel70
Russ Wooten
Role
Years of Experience
20
Tennant. It's Poly carpet, and you're right odor is the main concern. So far it's working ok but not perfect so I'm interested in what others are doing in similar situations.
Reactions: Jim Pemberton
You'll get plenty of good advice here.
With human urine, there is a great deal of volume of liquid involved, and thus far deeper penetration into carpet cushion and the subfloor.
I find the issue involved is less the product being used than making sure that the product that you choose to use reaches everywhere the urine has.
Frankly, if there are repeated urine intrusions from an adult human, it really should be time to consider replacing the carpet and cushion.
Axel70
Russ Wooten
Role
Years of Experience
20
