Adhesive removal
Rob Grady
Rob Grady
Good morning. I have a good customer who used adhesive backed plastic covering on his steps during construction. It was left on for about a year. He sent me this photo asking if I could remove the residue.
I am thinking to mist CitrusSolve, a wallpaper steamer to heat the affected areas really well and extract with my TM .
Have any of you ever ran into this type of problem? IMG_1710.jpegThanks for your input!
:eekk:
Make sure you get paid no matter what happens
Your concept is good, let me add a bit from my experience:
1. Its the customer's problem, get paid no matter what happens.
2. Citrus solvents leave soil attracting residues of their own. Make sure you follow the mist (I noted you said "mist"....you don't want too much of that on there) with a heavy application of a high pH, solvent boosted prespray (the nuke of your choice). This type of product is the mostly likely emulsify the adhesive AND the citrus solvent.
3. Lots of heat in your rinse/extraction step. Heat melts glue, and also will thin out the oily solvent.
4. Help the customer to understand that you can't see or feel the adhesive, so while the dirt will come off easily, the adhesive is clear, and may reattract soil over time. This is not bad cleaning on your part. Get paid no matter what happens.
Did I mention to get paid no matter what happens?
Nope, don't have "that good of customers". Does look like something a priest would do though or have someone else do. Sounds like a plan.
We have used and have had great success with Carpet Mastic residue removal.. UltraDry system from
ChemMax.. It's a VLM bonnet process different from encap.. You prespray the carpet, soak your synthetic bonnets in the hot catalyst solution, wring it out, and use your rotary.. We've had a small stair 175 rotary for steps.. The magic that happens using that system has made us the problem solvers since the 1990's..
The carpet mastic directions say not to leave it more than 28 days, I believe.. I know if you leave it down past a month, you're asking for problems..
We get a lot of calls from builders who use that crap..
I know you're in Canada, I'm not sure if you can get the product..
Rob Grady
Rob Grady
Yes , I believe before Paul Lucas took on the UltraDry system that process was known as MagnaDry in the States. My process for VLM in Canada utilizes the Roto-Static Cleaning Solution. Those two names have been around for some time, although I don’t know of any Magna Dry franchises still .
I have been a Franchised Dealer since 1978. I have the Husky 13” stair machine, that came as part of the tool selection we were provided initially. You can see my avatar is a Husky 17” proprietary technology unit.
Reactions: Nate The Great
Rob Grady
Rob Grady
:eekk:
Yes thanks Jim. I indicated upfront that I have a healthy minimum charge, and that I classify this type of work as experimental only at the customer’s choice to proceed.
I am working on another idea also, of how to approach this. I will be making an attempt this week and will update.
Reactions: Jim Pemberton
roro
Ross Craig
When faced with similar we went along Jim's line, of solvent boosted prespray but not completely successful. On the reservice, and acting more more in desparation we hooked a Little Giant 3HT in-line after our truckmount (Predator Unleashed)which was already running pretty hot as it was peak summer. so suspect we were hitting around 140 deg C. Had to wrap towels around the wands to hold them. Heat- the final solution worked.
That's 284 fahrenheit for those who don't want to Google the conversion
:eekk:
That kind of heat will melt any adhesive know to man I'm sure!
Nice having you around all these years here Ross
Johnny's Back
John LaRue
Role
Cleaning Professional
Years of Experience
25
This has worked for me, recently on nylon that was black from old film that had been pulled up about two years prior. Apply a higher concentration of high-ph prespray like Ultrapac Extreme with delim added, mist delim on top as necessary, scrub with fiber pad under OP machine like a Phoenix, rinse with alkali solution like Dry Slurry.
Start with a medium pad and change to more aggressive pads as necessary. I've started with Excellent Supply's beige pad and then needed a grey one. I've also used red and green pads. I think scrubbing with fiber pads is the key.
You can rerinse with acid solution and/or post-pad with cotton. Last adhesive removal job I did was in a house for sale, so I stopped after the alkali rinse. Looked great.
I think those stairs could be scrubbed with fiber pads on a hand machine.
they live
Steve
Ive cleaned several jobs like this. First time I had to go back and reclean because of resoiling.
Last time I used ultrapac mixed strong and hot then scrubbed with a crb. Its great on stairs. I hold it by the crossbar on stairs. Then HWE.
Then repeated the process. Checked on it later and no problems.
I cleaned the whole area effected before repeating the process using less ultrapac the 2nd time.
Reactions: Rob Grady
frank fratto
frank fratto
If they are willing to leave for one full day ,which in winter .I highly doubt. An if your willing to clean with a respirator . There is one sure fire way to remove it 100% . You would need a high heat truck mount . Pm for specific's .It will remove 100% but there are definite step by steps functions you must adhere too . The cost would be 1/2 of replacement value . If they are unwilling to leave for a day . Have it disengaged an done out side (best choice ) or in your shop.If you have one . But -yes dealt with it with a 90-100 % success rate . Your cost for the chemical agent . Would be around 40 dollars . For this you need to go very old school. An comparative items from a cleaning supply would be higher priced and less effective. The above answers will do nothing ,the closest any one came to getting it -Is Jim with the high heat remark,but 220 to 240 will suffice.I say respirator due to the fact you will be upclose and personal with a stair tool an even with ventilation.You need primarily to take your safety first and foremost. If your unwilling to go with the first option . Fel Naptha soap blended well with high heat . Should suffice -naphthalene is very effective in that situation. So the bar soap although less concentrated with heat will work . But like I said charge accordingly if using that as well. You might have to return 1 time a month for no more then 3 months .So as to rinse the soap residue out .But pm for the real step by step . I will give you each procedure in order depending on which one you choose. Citrus solvents will bounce off it ,water based solvent type detergents it will laugh at . What I will tell you will work . 413 356 8926 if you choose as well...No less then 400 on site and if disengaged add in cost of removal and reinstall. Which honestly at that point tell them new .An the moral is never use that crap again .It would have been far easier to just clean on a regular basis versus that junk they used . PM or Call !
Ok I'm jumping in this post .I've done this more than once with similar carpet.
People out of the house for 3 hours.
Respirator- Eye protection - Gloves.
Ammonia and 30 volume small amount water mix in sprayer .
Light spray agitate very well.
Then,
VLM- walk away, come back next day and be a AMAZED!!!
NO STEAM.
Then,
NO STEAM.
Ammonia can pull color does it matter if it's polyester less likely to loose color or nylon?
More likely to lose color.
What % of ammonia to peroxide?
frank fratto
frank fratto
Sam, home depot
In 45 years of using ammonia
never have i pulled color using it with VLM . {No more than 3 attempts}
YES i have pull color with Steam !!! [ DAMMIT ] HEAT.
half & half small amount of water.
Numero Uno
Caesar
Then,
NO STEAM.
Ammonia and 30 volume to remove a gummy residue ? Guess it worked for you -regards.
Numero Uno
Caesar
I'm not saying you did .I just don't see how that combo would work effectively against a gummy residue .But It obviously did. I learned something new as well .But hopefully the gentleman with the problem gets it off and makes some good profit-Regards.
Reactions: frank fratto
KevinD
Kevin Dumas
I find the best aid in making sure you remove all adhesive is to run a teflon glided wand over the area.
For some reason residual adhesive really gums up the bottom of it really well if any remains.
sassyotto
Paul
Paul,
Nice Job!!
What chemical?
What process?
this was the entry from the garage. I cleaned the rest of the carpet (including steps which were WET when I took the picture) and started to work on the two strips in front with DeSovAll and ran out. Went to Home Depot and got an adhesive remover for carpet and that worked pretty good. Between DeSovAll, Citrus Force (diluted) and Home Depot Product and a lot of time, got it all out.
Reactions: Kenny Hayes
frank fratto
frank fratto
I think it looks damn GOOD!!!
Reactions: sassyotto
