- Sep 15, 2007
- 44,660
- Name
- bob vawter
I break every grandy groomer I run across !
How can anyone be that dumb?
I was born that way!!I break every grandy groomer I run across !
Its not his problem.I was born that way!!
Do you have a problem with THAT??
GOOD!!!------------Its not his problem.
If you know how to wand, you wouldn't leave little or big trees BobI break every grandy groomer I run across !
If beginners would do the dual process,ConDog is not, I repeat, is not going to the dark side. Where you been Con? Y'all just skipped right over the two porty extractors. THAT makes him a dual method cleaner when the need arises. Not real sure you could put him in the VLM only category.
I’d put him against any truckmountConDog is not, I repeat, is not going to the dark side. Where you been Con? Y'all just skipped right over the two porty extractors. THAT makes him a dual method cleaner when the need arises. Not real sure you could put him in the VLM only category.
Like someone else asked...George and matt and steve,
I think "what do i know?"
VLM is as good if not Better!
I think it actually gives the carpet more life not less! {if done properly}
Pads washing though the 1 inch carpet fiber,
Pulling soil, and resetting the TWIST!
Just makes so much sense to me!!!!
Just don't see myself going back to a truck mount??
Who's evidence yours or mine????Like someone else asked...
Do you wash your pads in water or vacuum then to get them clean?
How fast do pads load up with detergent and soil before they should be changed out?
Do you go back to vacuum after the carpet is dry or expected the homeowner to do it with their $59 dollar Bissell?
Why do carpet manufacturers recomend HWE?
Make your money that's what its about i guess but no matter how much you claim its better the evidence doesnt support it.
Do tell ? Explain??You're making assumptions on all but 2 replies.
And those are questionable.
Look what is going on my VanRobin,
Is absolutely Right!!!
Mixing it up and having FUN!!!!Look what is going on my Van
Next time I have Apartments to do at my Apt Complex I'm giving the 13'' Hawk 175-300 a try
I will use the Bonnet Pro Multi Brush to scrub and 15'' Iron man to extract
I haven't used it for at least 10 years
I bought it around 2010 to scrub trashed rentals when I was still HWE
And used it when I first started experimenting with VLM in 2012
You don't realize how show a 175 is until you use a 300
I love having that option
Look at how small those wheels are
You guys do realize? carpet cleaning companies in big cities,I heard it all before from the von Schrader dry foam people(their all gone) then it was the Host guys (their all gone now too). After them the chem-dry rub n dash guy's were really loud, they stood on their soap boxes and preached the same sermon as you for 30+ years i might add lets see what are they doing??? O ya! They HWE now( after 35+ years of vlm) but they say their still better cus their solution is carbonated. (And mine is not) what ever my challenge still stands come on down ill show you what CLEAN really looks,feels, and smells like. And you won't be able to come close to achieving it NO MATTER HOW MUCH YOU RUB
Same sermon, different soapbox. People starting businesses these days wanta get into it cheap and easy. We see it in carpet cleaning as well as window cleaning. Us old timers use a brush and squeegee. Kids these days wanta use deionized water. Why because it's easier faster more profitable not better. Come on down take the challenge, beat me and ill preach your sermon the loudest. But till that happens im not drinking the kool-aid ReverendYou guys do realize? carpet cleaning companies in big cities,
San Francisco, Chicago, NYC, some of the most expensive real-estate Highrise condos use?
VLM, because of noise restriction.
not only is it here to stay,
but it will take over the industry?
No one is making new steam cleaning chemicals?
But everyone is coming out with NEW
VLM CHEMICALS!!!!!!
I wonder why? it's only been around for ---100 years..............
Most truck mount companies been bought and soldI heard it all before from the von Schrader dry foam people(their all gone) then it was the Host guys (their all gone now too). After them the chem-dry rub n dash guy's were really loud, they stood on their soap boxes and preached the same sermon as you for 30+ years i might add lets see what are they doing??? O ya! They HWE now( after 35+ years of vlm) but they say their still better cus their solution is carbonated. (And mine is not) what ever my challenge still stands come on down ill show you what CLEAN really looks,feels, and smells like. And you won't be able to come close to achieving it NO MATTER HOW MUCH YOU RUB
Dwain, in your shop you are the KING!!!Same sermon, different soapbox. People starting businesses these days wanta get into it cheap and easy. We see it in carpet cleaning as well as window cleaning. Us old timers use a brush and squeegee. Kids these days wanta use deionized water. Why because it's easier faster more profitable not better. Come on down take the challenge, beat me and ill preach your sermon the loudest. But till that happens im not drinking the kool-aid Reverend
George,Mixing it up and having FUN!!!!
All things being equal time should not be of any concern, right?The true test is to come back the next day.
the next week.
the next month.
You can guarantee the following will occur:
After you clean with the most powerful TM or portable go over the carpet again with a rotary or orbital and you will see a difference as more soil is removed.
After you clean with either a rotary or orbital go over the carpet again with the most powerful TM or portable and you will see a difference as more soil is removed.
A professional cleaner will understand.
Yes, I do use both methods as they both have their own benefits.
Happy cleaning guys.
All things being equal?All things being equal time should not be of any concern, right?
wait a minite....are you in this to make the carpet clean orAll things being equal?
VLM ,WILL LOOK BETTER A WEEK AND A MONTH LATER....
I guess if a cleaner leaves detergent in the carpet that might be true, but who does that?All things being equal?
all them little old black ladies in the ghettoIf you know how to wand, you wouldn't leave little or big trees Bob![]()
jus lik the daze of Gurkinky only backwards............I've come to really love my Grandi
It should be all a 2%r needs, along with some patience and understanding.
I believe it's the latterwait a minite....are you in this to make the carpet clean or
load up the bank account.....!
