Is it easy to use, I'm 62 and just had my 2nd knee replacement and wanted the easiest machine that will still do a good job? will the driver bristles bend if you let the machines weight sit on them for extended periods? I read your earlier posts (helped me make my decision) that you like "Vacaway Double Trouble" I like Vacaway Encap Green, do you think Double Trouble is better? and i'm going to use mostly microfiber pads cause I don't have a washing machine to keep cotton bonnets clean, are the microfiber or microfiber with scrub strips better with the Odyssey and do fiber pads last or just get chewed up? Sorry, I know that's a lot of Questions,,I've have been using Odyssey since 2020
I use it for small residential homes
CRB to scrub and Odyssey to extract
Yes Odyssey is very easy to use and easy going up and down stairsIs it easy to use, I'm 62 and just had my 2nd knee replacement and wanted the easiest machine that will still do a good job? will the driver bristles bend if you let the machines weight sit on them for extended periods? I read your earlier posts (helped me make my decision) that you like "Vacaway Double Trouble" I like Vacaway Encap Green, do you think Double Trouble is better? and i'm going to use mostly microfiber pads cause I don't have a washing machine to keep cotton bonnets clean, are the microfiber or microfiber with scrub strips better with the Odyssey and do fiber pads last or just get chewed up? Sorry, I know that's a lot of Questions,,
