What do you use???
Dwain Ray
Im new to tile cleaning. My machine Frankenstein came into being because I wanted to offer tile and grout cleaning and my perfectly good 20+ year old machine wouldn't create the pressure to do it. I purchased approximately 2500.00 worth of attachments to perform the job now that i have a few jobs under my belt im questioning the quality of the attachments i was sold by my local supplier and I am about to start replacing them. The problem i have, is buying off pictures and what salesmen tell me .i worry that i could be jumping from the frying pan into the fire. This is a service that i don't have much experience in so I'm asking you guy's what are you using day to day to clean tile? what do you like about it? and probably more importantly what do you dislike or would change if you could? I talking about attachments, wands,heads, hand tools etc. Also what do you have that you consider usless and wish you didnt buy? and/or you never use? Also what do you have that you can't do without? Im hopin for some good input im less concerned with price and more concerned with quality and performance. If i jump ship im doing it soon. Please help me make an educated decision. Thanks in advance. Dwain
Cleaned tile all day today. 4500 sq ft of a commercial kitchen, party room, bathrooms, hallways.
CRB, th40, and Mike’s tile wand is all you need. And a few different scrub brushes
I have a CRB that we occasionally use, but since it won’t get into corners or under cabinets or along baseboards we seldom use it. We have spinner tools but seldom use those either. All I normally use is Saiger’s tile cleaner, my floor wand from Mike and a Duprey Steamer from Amazon on the grout if it’s stubborn.
Dwain Ray
Thank you for your input. With your mikeys wand which heads do you have? Did you drill vac relief holes? If so did it make enough difference? Have you used anything else other than a crb to prescrub? Im starting slow and working up to big jobs. Mostly kitckens/laundry rooms and bathrooms. I dont own a small scrubber only a pullman holt 15 or is it 17"industral floor polisher. The few times I've needed to use a small scrubber ive borrowed a friends 13" oreck orbital.
Dwain Ray
You use the steamer instead of a scrub brush or both? Do you have just one size head for your mikeys wand?
