- Oct 6, 2006
- 117,283
Atomization takes our "Pre's" further and wider than you might realize..Did they apply the pre-treatment to the walls and chairs? Was it careless?
So what's the solution?Atomization takes our "Pre's" further and wider than you might realize..
My question isn't just about urine treatment but the whole priest spray in the swiping of left to right with our two foot hydroforce lances..So what's the solution?
Isn't the Urine also destructive, more so after it converts to Ammonia?
Paul,if I need to prespray right up to a piece of furniture that Im not moving, I will still tab it just to be sure.
Or just wipe off the legs and baseboards.My question isn't just about urine treatment but the whole priest spray in the swiping of left to right with our two foot hydroforce lances..
On your next job after pretty spraying a furnished room you may want to go touch the legs and skirts of the furnishings to see what you've created or left behind rather...
Maybe the answer are those colars we put around our dogs after surgery
I know you didn’t ask me the question, but in my experience it is rare that an elderly person has no way to remove the blocks. They usually have kids that visit frequently or a cleaning lady that comes once a month that can remove the blocks.Paul,
I appreciate your effort!
But if the customer is elderly and has hard time removing blocks and tabs and
just want the traffic areas clean?
Do you go back and remove them?
When I started out I was tabbing and blocking everything. Then the next visit they would still be there on some jobs so I adjusted how I approached it.I know you didn’t ask me the question, but in my experience it is rare that an elderly person has no way to remove the blocks. They usually have kids that visit frequently or a cleaning lady that comes once a month that can remove the blocks.
If they really have nobody to help them, we won’t wet under the item that would otherwise need blocks. Almost always there is a compromise the customer understands and agrees to.
Dkane,I know you didn’t ask me the question, but in my experience it is rare that an elderly person has no way to remove the blocks. They usually have kids that visit frequently or a cleaning lady that comes once a month that can remove the blocks.
It's a I don't like saiger from someone who hasn't used himOr just wipe off the legs and baseboards.
Getting old isnt easy. Maybe use one of those grippy handles with a towel if you cant bend over.
It sounds like a communication and expectation problem.
good question!Paul,
Paul, you are a 2%good question!
During the walkthrough, if a customer says "traffic" or "open areas" I still clean all the exposed carpet. So everything you see is cleaned. I use the old Prochem upholstery tool to clean along the base trim and right up along furniture I dont move. That being said, once in a great while there is soil going right up to a piece of furniture where I will need to prespray right up to it. In that case I would put a plastic or foil tab under the leg.
I never had anyone ask me to come back to remove them although I wouldnt mind doing so. I find it common that if they are elderly, their kids or someone they know have the areas prepped for me.
True, this wasn't a thread meant to pick on Mark but rather to address that the atomization the priest spray in the moving hydraforce or pump up or any electric sprayer doesn't get on a lot of stuff.Mark gets a lot of criticism for his videos. They are annoying, but his techniques and his products are first rate. It’s normally just jealous competitors or clueless internet warriors.
Divulging on atomization; if we set our machines to lower pressure, stop swaying the lance like there is no tomorrow, maybe we wouldn't have to worry about furniture/ SS damages from prespray. I rather take a customer’s complaint that I missed the spot than damages to wood or the stereo. With a competition making false claims nowadays ( we remove 98.9 allergens from your home) in order to lure customers in, I counter with excellent drying times in writing ( less than two hours).My question isn't just about urine treatment but the whole priest spray in the swiping of left to right with our two foot hydroforce lances..
NopeTrue, this wasn't a thread meant to pick on Mark but rather to address that the atomization the priest spray in the moving hydraforce or pump up or any electric sprayer doesn't get on a lot of stuff.
Have any of you ever had a customer complain that you caused any sticky residue or brownouts or worse?
Eventually the baseboards with compressed sawdust will go away and we can continue flooding the floorsHow many of us are swelling baseboards, and none notices..
another reason to clean for high end customersHow many of us are swelling baseboards, and none notices..
That can fool you though. My high end customers mainly live in two different subdivisions with 4500 to 500o sf two story houses that are built by Stone Martin Builders. They’re build so cheaply that I wouldn’t be surprised to find particle board baseboards and Chinese drywall in them. I find wall sockets with no power, leaking shower pans, visible drywall seams and other things I’ve forgotten in them. People buy them because of the neighborhood.another reason to clean for high end customers
