A piece of clear aquarium type hose ( too bad you didn't put it on before installing the end) it might be a little tight getting over the ends .or maybe 2 or 3 layers of heat shrink would do it thats what i used on my chem pump lines some hoses i completely cover in plastic hose and seal ends with shrink tubing if for instance abrasion could be a problem but generally speaking when making ⅛" hoses i slip on a piece of plastic hose for support at the ends while making umthat would make this more secure? This is a replacement hose for a Sapphire Upholstery tool. it broke at this point (weakest link)
something like a hose bend restrictor on a solution line.
The marine grade shrink wrap is best because it has a glue inside to bond the wrap to the hose (its purpose is actually to further waterproof electrical connections in a marine environment) . Where as heat shrink that doesn't say marine grade doesn't have thatView attachment 134376
Reviews say it remains stable under heat
No problem glad to helpbought some. great idea Thank you!
