100% VLM ???
they live
Steve
Just got a call to do carpets she wanted to know what equipment i was going to clean with i explained what frankinstien was and did. She said she was just making sure i wasn't going to just clean with a "floor polisher "like the last guy did he was in and out in very little time was very expensive and did a terrible job quote un quote i have no idea who it was no carpet cleaner around here offers vlm it would have had to have been chemdry from over the hill in ukiah
I had one a couple weeks ago that had been getting done by a local padder. He said mine dried just as fast but was way cleaner.
I often hear about how I leave the carpet soft and fresh smelling.
Kenny,
Is that because you was trained with a Bane-Clene?
Less water? Seems that carried over to your real truck mounts?
I actually started with a porty. Then went to a Bane. Then to the truckmounts. Still do more porty work because it's just easier to reach on 2nd floors. Knew how do
bonnet work with the 175 using the green stripe bonnets and bought a bonnet machine less the Chemstracter. It was decent but chemicals were crap back then. I was more concerned with vct than carpet.
Reactions: frank fratto
On a average size room I use about 1 gallon of water using my WORX Sprayer
HWE uses 5-6-7 10 ??? times the amount of water VLM uses
So compared to VLM, HWE FLOODS the carpet with gallons of water
TM's don't come with 20 gallon dirty water tanks for a reason
They come with 70-110 gallon tanks because HWE uses and WASTES Huge amounts of water
LESS water MORE agitation !!!
I may use 10 gallons of water but if I recover 8 gallons, that's the same or less as what you use.
  • Wow
Condog
Tony
You like using that word to fit your
your narrative. I suppose it helps you feel better about your processes. My PEX 500 don't flood carpet nor does my small truckmount. That's ridiculous and ignorant to say so.
I thought about getting a Pex 500, but I have a Ninja I like and chose the Monsoon for vac power.
So I have something to consider, why did you choose the Pex 500 over a Monsoon or Mytee?
Condog
Tony
Here ya go just for you vlm guys. Vlm for your clothes! Only clean your clothes with this shit for 6 months or so and let me know how it goes. If you truly believe vlm is the only way to go then walk the talk.why are you wasting water and electricity cleaning clothes???my offer still stands that 100oz of silver is now worth $7,754.00 right now.
Terrible comparison.
Every instructor will tell you to limit the amount of moisture you put on carpet or upholstery; a washing machine soaks, rinses and spin dries in a way no extraction tool can.
Clothes don't have padding like carpet and upholstery, which we need to prevent from bleeding color or deposits onto the surface.
Carpet Muscle has a video where he pulls the piss soaked carpet, tore out the padding, cleaned and sealed the cement, put in new padding, cleaned the underside of the carpet, stretched and installed the carpet, cleaned the top of the carpet.
I'm trying to point out there are methods of cleaning with vlm for even piss soaked carpet and people willing to do the work.
I watched another video where they used OSR and soaked and extracted doing the same thing Carpet Muscle did.
Maybe you've been blessed and the other man doesn't have your good fortune, opportunities, experience whatever and he may be doing the best he can.
We shouldn't knock people down who work hard, we should encourage and help each other.
Condog, Dang, that thing is easy to maneuver, load, and is quite. Has a side discharge hose and a hose hook on other side. Pressure release valve really is handy and it has good heat. For carpet tile and cgd, it's awesome. P.S. I was one of the blessed ones that had a Mytee catch fire in a customers home. That too was one of the things that #burnt me on residential, literally😬
Reactions: Condog
Dwain Ray
If you'd read more than one or two posts in this conversation you would clearly see that im simply definding my process as are all the other real carpet cleaners here and you'd also clearly see that my comments about vlm clothes cleaning was a sarcastic shot across the bow of the oppositions ship
frank fratto
frank fratto
Carpet Muscle" Corey" He is a really good guy!!!"
Reactions: Condog
frank fratto
frank fratto
If it dried just as fast?
What the hack did the VLM guy do to that carpet??
He must be a " MUD MAKER "
Steve, good job on soft and fresh smelling!!!
frank fratto
frank fratto
"REAL carpet cleaners OK if you say so"
frank fratto
frank fratto
But you are not removing it. You are diluting it like Dwaine mentioned. Except you are not extracting it. Wet bonnets do not extract. They just absorb the dilution.
OSR ,Will destroy urine!!!
There's a process...
I know you don't trust me? but trust me?
My process works!!!
I've done hundreds maybe thousands with steam and VLM ....
But there's more to it than I'm gonna explain on here?
