100% VLM ???
frank fratto
frank fratto
I sleep good at night knowing my equipment NEVER fails me ... ANYMORE
And if somethings does happen I got backups for everything
Since your equipment NEVER fails, why would you need a back up.
Jeff,
GOOD POINT!
Maybe because I can fit 3 in my van, takes up less room in my garage LOL!
What do you mean "ANYMORE"?
Kenny,
Can you or anyone else explain to me what is so special about a PTO or any TM that Spits and Sucks?
And they start at $20,000 and go up and up in price?
And I can take a 175 for $1000 and accomplish the same results all day long!
Please explain it to me. WHAT AM I MISSING??
How much soil do you really believe you're extracting from residential padded carpet with a bonnet? You can't tell roll it around
and wring it out and get another one, but I assure you, and you know if you're honest, you're not removing what a tm can. Put a crb, or a bonnet pre and post with the tm, if need be and you've got a killer combo.
Reactions: frank fratto
frank fratto
frank fratto
I Politely disagree.
If it's being done right?
VLM, will and can extract more soil then a TM with 3 Soak passes and 3 suck passes.[Anything more you're making mud}
VLM can keep applying a light pre-spray and keep extracting as long as it takes to get the job done right.
With out making mud.
I just got back from a small 2 bedrooms and one of them, I did just that, turned out Great!!!
That is my Honest opinion...
frank fratto
frank fratto
Most" no some" TM guys,
Try to clean the carpet and the pad at the same time.
Always turns out to be a big mistake...
  • Eyeroll
Reactions: Kenny Hayes
My point about the pad is you can vlm cgd, carpet tile that is laying on
cement to help reduce wicking and get that carpet clean using low moisture methods. Hey, the Encapstore has chems for residential carpet cleaning, and so be. I wouldn't do it, but I don't do much residential anyway.
frank fratto
frank fratto
And most people was never going to buy a Battery car?
But they sure love their Tesla!!!
SteamwayPro
George
There is my Dirty Water Tank
That dirty water in my washing machine looks just like the dirty water that comes out of a TM dirty water tank
It looks exactly the same as the dirty water that used to come out of my TM
When you put your used bonnets into clean water in your washing machine and the water turns BLACK you know VLM works
I love VLM !!!
  • Love
I like my electric extractor too, so what? I have the same $hit you do.
I'm like Matthew Quigley with a handgun, I didn't say I couldn't use one, I said I didn't have much use for one.
frank fratto
frank fratto
I'm just saying it makes me wonder?
Steamers who dabble into VLM?
I'm guessing are not getting the results that George and I are receiving in VLM?
I would ask myself why I'm not getting better results??
What can I do different??
Because we figured it out!!!
The old saying?
When you know, you know!!!
Reactions: SteamwayPro
By the way, my tm and van is paid for, and the one in my trailer is too and been for a long time. Don't cost me much. They're small since that's not my thing. The van works as a trailer puller for other things more than anything, but it just happens to have a truckmount in it. Cost isn't a big thing to me.
frank fratto
frank fratto
The sh*t I say on this thread is for the new guys?
I'm sure they don't want to hear it?
But someone's reading this thread 197K WOW!
Who are these people??? LOL
SteamwayPro
George
Frank we both use VLM but do everything different
I use a OP CRB and WORX Sprayer and you use a 175 and I think Electric Sprayer but we both get the same results
Cleaner Drier Carpet and Very HAPPY Customers
And HUGE Profits
The KEY to our success is LESS water
You don't need a lot of water to clean carpet
You just need enough water to loosen dirt that's attached to the carpet fiber and keep in suspension until it's absorbed extracted removed
The more water you use the more problems you can have and will have
The Number One question I get is how long will it take for my carpets to dry
MOST customers don't care how you clean their carpet but they DO CARE how long will it take for the carpets to dry
WATER is your FRIEND and your ENEMY
Oxy-Dry uses that quote a lot and it's so TRUE
LESS water MORE agitation !!!
  • Love
they live
Steve
90% is alot different , it's considered junk silver and it falls into the same spot category as old jewelry and sterling silverware. My guy doesn't buy that stuff. But .999 coins,rounds and small bars(up to 1kg(1000g) ) is not a problem my guy wants1.25 under spot for 100oz bars and won't accept anything larger
Yeah I read up on it after your reply. I had assumed it was all silver from the way I was told.
frank fratto
frank fratto
And HUGE Profits
George,
You're absolutely RIGHT!!!
frank fratto
frank fratto
You and steamway mostly.
Steve,
I'm very open -minded and can easily change my mind on just about anything if it
makes sense to me?
Please help me understand what you know that I don't know?
I'm listening and I just haven't heard enough evidence to convince me to go back to to steam cleaning?
I KNOW IT'S MY BAD?!!!
SteamwayPro
George
The old saying?
We figured it out. EXACTLY !!!
It takes a while to figure it out
And when you do figure it out WOW
You can't just do one VLM job a month or one every 6 months and figure it out
I didn't figure it out until I switched to 100% VLM
You gotta work at it and learn how to clean carpet all over again
You can't BLAST AWAY using WATER PRESSURE to clean with
I started experimenting with VLM in 2012 because VLM just made sense to me
TOO many problems using a TM and the HWE Method
But for many years I only did 5-10 VLM jobs a year using VLM so I never really figured it out until the 100% switch to VLM
I didn't know you could get the results on Residential I get now and never even dreamed of getting the results and PROFITS I get now
I love VLM !!!
frank fratto
frank fratto
I love VLM !!!
George,
Once again you're absolutely RIGHT!!!
they live
Steve
Steve,
makes sense to me?
Im just saying where most of the veiws are coming from lol
SteamwayPro
George
More fun at my Apt Complex today using my 13'' 175-300 Hawk using the tank and Carpet Details
Bonnet Pro's Multi Brush to scrub with fiber pad insert
17'' Driver with 19'' Ironman Bonnet to extract
10'' CRB to groom
The carpet was spotless but it still must be cleaned to pass Township inspection before new tenant moves in
EASY MONEY !!!
Hey Frank have you ever used a 300 ?
Life is BETTER when you're using the VLM Method !!!
Yo
frank fratto
frank fratto
10'' CRB to groom
EASY MONEY !!!
View attachment 134069View attachment 134070
Yo
Only once on VCT job long time ago never on carpet.
I believe carpet muscle uses it? I could be mistaken?
Rick J
rick Jones
10'' CRB to groom
EASY MONEY !!!
Yo
man, I had a 175/300 power flite , but it was stolen
