Jamesh921 said:
What about installing a Kunkle or SOVC valve? Do you think that that would generate enough vac to "truly" double-wand?
The relief valve on a PM is one of the best spring type valves in the field.
It's a very very good valve
I tried a Bayco for a day..I sent it back.
regardless, it's still a 45 blower, which i consider "the" blower to have for a single wand TM.
But it just doesn't have enough CFM for true dual wand use.
and with a wye running two wands , it will be dismal vac...cheap porty vacuum performance.
the pump and heater gives more than enough for "true" dual wand use, but the 45 blower just can't move enough air @ max manufacture's recommended spec limits.
It's easy and cheap enough to try for yourself though.
For appx $20-$30 bucks you can make your own wye.
The TSC farm supply store will have everything you need.
PVC pipe and wye's as well as 2" hose barbs
Lauren makes a good point about lasting longer compared 1/4 "steel" braid.
(still not worth the weight and bulk imHo)
But it doesn't last any longer than Parker Parflex.
Which is lighter , carries more heat to the wand and is not as hot to touch as 1/4" steel braid.
We're run Parker for better than 17 out of 20 years.
I've only used steel braid for a year or two....that was enough for me...
Parker is stiffer than steel braid though.
Some guys don't like it for that reason.
