Auction 17" inch Trusted Clean Carpet Brush
MB Auctions
Description:
This nylon carpet scrubbing brush has two outer white rows of bristles that are heavier than the inner black bristles. The outer white bristles are used to scrub the carpet and flex the pile while the softer inner black bristles "massage" the dirt from the carpet for a deeper cleaning action. The carpet glide center cap allows you to continuously scrub your carpeting at the same height, without allowing the bristles to dig too deeply into your carpeting. For use with our 17" carpet scrubbing floor buffer, or other similar sized rotary carpet scrubbing buffers. The top of the block features showerfeed holes for direct dispersion of you carpet cleaning solution on to the carpet. Our 20 inch brush also features these holes, where as our 13 inch and 15 inch carpet brushes do not because the block is not large enough to fit those holes in. We strongly recommend putting this brush through our "break in procedure," before you use it on any type of carpeting. First remove the guide so you don't scratch it up. Second run the brush on a concrete surface for about 10 minutes to remove burrs and slightly tip the bristles outward. This will help to protect your customers' carpets from being torn, ripped or frayed from a burr on a bristle. Learn more here: http://www.cleanfreak.com/equipment/floor/floor-supplies/brushes/buffer-brush/17-inch-trusted-clean-carpet-brush.html Free Shipping to Lower 48 only. $111.43 Retail
Bid Now at Cleaning Classifieds
** You must create an account in order to bid on items. Your Mikey's Board credentials will not work. Click the following link to create your account: http://mikeysboard.com/classifieds/index.php/register.php **
