- Joined
- Oct 6, 2006
- Messages
- 117,061
Try this you 2.5ers.
On the next cleanable* wool area rug you clean on location vacuum it front and back real well, start with the back. Show the home owner what you just vibrated out. A Sanitaire will excel at this due to it's true Beater Bar. Then sweep up the floor then go over the front 4 ways to Sunday. Show her what's in the DirtCup at this point.
At this point lay the rug over some painters plastic.
Pre spray the heck out of it (front only) and the fringes. Scrub it with a white pad on your 175, give it a few minutes of dwell then take your Greenhorn or Ti high flow wonder wand at full heat with ONLY your 2.5 hose (no whip) and rinse and dry stroke real well. With a Hole Glide you can rinse the fringes with no fear of distortion. Let them stick to the Glide and let some air flow through them for a while.
( you can pray and clean the back too if you can leave them with a airmover and a way to hold down the rug.)
Bend over and feel that baby now.
Tell Mrs Pift to bend over and feel too.
$2.00 a foot no problem
if not more...
*-no bleeders or shrinkers
if not more...
