2.5 Y mounted sideways
Able 1
Wi
Keith
In order to have my passenger seat in my van I had to mount it to my TM. I have great vac. but was wondering if it would be even better if I mounted it to the floor. Makes me think the waste water is all going through the bottom one. The two 2" hoses I have hooked up have smooth insides, what do you think?
Thanks,
Keith
p have a smooth inside
With the Y in the vertical orientation, you probably are getting some bias, but I'm willing to guess it's minor, if it's not convienient don't go and move the Y.
btw: that is some heavy duty hose, regular 2" vac hose will serve just fine unless you have an engine heat issue to consider.
Able 1
Wi
Keith
btw: that is some heavy duty hose, regular 2" vac hose will serve just fine unless you have an engine heat issue to consider.[/quote]
I do have some heat issues but trying to fix them...
Thanks
Keith
