3/4 or 1-Ton Butler?
Which did you or would you get, 3/4 or 1-Ton?
Thanks
Richard
M
Matt King
1 ton. Unless you're using a portable or you're a padder I wouldn't consider anything else. Especially if you plan on carrying water. The difference in price isn't that much and you'll save on brake jobs in the long run.
K
Ken Snow
I didn't even think Butler was offered in a 3/4 ton anymore unless you mean the Ford- which I believe voids the ford warranty. We only use GMC 1tons.
Ken
Lou said I can get 3/4 with 8600 GVW or 1-Ton
I'll take your word for the 1-ton.
Thanks guys!
adamh
I have had a 1 ton and a 3/4 ton. Never will I go back to the smaller.
Doug Cox
Doug Cox
I prefer the 3/4 ton vans only for the ride. Brake jobs are easy to do so I wouldn't buy the 1 ton for that reason. I bought Matts equipment and was concerned when I found out how heavy it was, but it rides remarkably well with the machine and the water tank full.
Becker
Hey Ken,
Last I heard ford is working with van powered machine manufactures now.
If this is true, then maybe Chevy will work harder at fixing the fuel pump issue.
3/4-1 ton is another spring, otherwise every is the same.
You don't want to max out the payload, so why not go 1 ton.
Bill
One ton extended....I bought the whole package from Butler. For some reason, they seem to have the best package w/o a lot of hassle. Hate buying trucks....the Butler GMC is well engineered and thought out. They have the suspension package/tyranny ratios figured out. Also, they have a different sway bar or something on the front end that is a minor option.....but the front end holds alignment better and the tires seem to wear better compare to last one ton I bought myself in '03.
Bill in central Florida
