36 Blower / ProChem Quad Wand
  • Thread starter What A Difference Ky
  • Start date
W
I have a Warrior TM from TCS in ATL. It has a Kohler 19 hp and Sutorbilt™ 3L DSL @ 288 CFM vac blower which I believe is compared to a Roots 36.
I run a 6' 1.5" hose to my 2" recovery hose. I'm using a standard 1.5", 2 jet generic wand with a glide.
Would my system support a ProChem Quad wand and if so, how much better do you think it would be?
http://www.tcsatl.com/warriorkohler.html
:lol:
I think Pigsnot used to run that combo. Lets see if he sticks his snout in here! :pig:
Captain America
Yea bro
Prochem quad jet had great air flow and recovery...a little heavy...gotta have a glide on it and you'll be fine
I have had 3 prochem quad jet wands with gren glides...the best wand for cleaning I have ever used....
Use the 2 inch hose all the way to the wand and it will work great....has to do with jets and water flow...you can experiment with the jets to see what your truck mount can revover.....
The cap
Bjorn
your system will work with just about any wand or combo
a two inch tube wand might help a bit the 1 1/2 inch whip hose is no big deal not sure your customers are going to notice it took 15 minutes longer for the carpet to dry.
2 inch tube non ti wands are going to be a bit heavy
everything is a trade off.
pick which works best for you and your back not worry about 3 thousand others will tell you something different
