- Joined
- Oct 6, 2006
- Messages
- 117,225
I have been testing one for a while now would have to confirm that it is indeed 20 to 30% faster than the 3 port head..
Not sure of the price but I'd guess around $450
You'll have to do the math to decide if it is cost effective to upgrade..
Mike,
The true advantage of this new head is performance over time. Eliminating the foam gasket allows the new head to maintain its flow properties for the life of the head. The standard head will degrade over time causing cleaning times to increase. The new head is sealed with an o-ring gasket that never sees the debris that is recovered. All of the recovered water and debris is contained between stainless steel top plate and the head.
The quad head has half the air restriction of the standard head. The new flow chambers are also tapered to better maintain the pressure drop across the entire swoop shoe. The spacer has also been incorporated into the head to smooth the transition between the head and the hub. These changes have taken the air restriction from 7.4% to 3.7%.
The flow improvements aren't huge but every little bit helps. The simpler design works better, will last longer and is easier to clean.
I will work on getting some shims made this week and will get them to you for testing.
Some real life numbers
25' of 1 1/2" vac line 18.5% restriction
50' of 2" vac line 11.1% restriction
360i with a standard swoop shoe head has a restriction of 7.4%
360i with a quad head has a restriction of 3.7%
3 stage CFX, 360i with a quad head on 25' of 1 1/2" line you would have a system restriction of 22.2% or 210 CFM.
3 stage CFX,a 360i with the standard head on 25' of 1 1/2" line you would have a system restriction of 25.9% or 200 CFM.
3 stage CFX,a 360i with a quad head on 50' of 2" line you would have a system restriction of 14.8% or 230 CFM.
3 stage CFX,a 360i with the standard head on 50' of 2" line you would have a system restriction of 18.5% or 220CFM
350 cfm truck mount a 360i with the standard head on 50' of 2" line you would have a system restriction of 18.5% or 285 CFM
350 cfm truck mount a 360i with a quad head on 50' of 2" line you would have a system restriction of 14.8% or 298 CFM
Thanks
James Von Protzeller
Engineer
RotoVac Corporation
