WillH
what's up guy I got problem as you can see. The 360i spins but doesn't spray water. I bought used the guy said it only has a few hours on it and it looks new. Does anybody know what it could be thanks for the help.
Nate and Porkchop are right start with the simplest. Could be the small solution supply ball valve, inline filter, could be a broken (Freeze Damaged) valve. Follow the solution system and see where the flow dead ends. Has to be a simple problem.Check the q/c first.. Then the inline filter, then take off the jets, process of elimination..
WimpNo I haven't even looked at it yet. I broke my leg and been out of work.
