360i on commercial glue down
rcl1006
i don`t do much commercial work, since i started using my 360 it`s hard to grab the wand. i have a job tom night 3000 sq ft retail store. light color commercial glue down. how is the 360 on com grade carpet , what psi should i use and what speed would you recomend.
using it with a bawb v steam genie
thanks rob
joeynbgky
Joey
I think it sucks on gluedown. U will more than likely have to use ur wand. But if u do try it, let us know how it goes
Sent from my T-Mobile G2 using Tapatalk
crank it up on high and set the PSI at about 300 to 350..CGD is one of the few types of carpet that the 360i does a great job...
joeynbgky
Joey
Re: Re: 360i on commercial glue down
I disagree lol a whole lot.
just do the above..find a good over lap pattern that you are comfortable with do a quick dry pass and it will do a good job for you...
I have used it on many CGD and berbers and never had a over wetting problem or any cleaning issues...flushes the hell out of these type carpets...
I used it on carpet squares the other night at a verizon store and it came out great...
forgive me, but if you own the damn thing, how hard is it to wheel it and a wand into the joint and find out for yourself??
here's a tip that might help...
wand a 50sf section then 360 50sf section .
if one is better than the other, use it
if you can't tell any difference, use the tool that's easiest or fastest ...take your pick
this ain't rocket science ....
P
prestige cleaner
300-325 psi with the speed dial on 6 works the best for me when i use on cgd.try Jim Martin's method first...
M
Mike Draper
Holy shit, for the first 2-3 years i was in business all i used the was the 360. No matter the type of carpet, i used the 360 I put over 1000 hours on my first 360. I would be embarrassed to clean CGD with the 360 now, knowing what I know. A pre-scrub and a wand will out do it any day of the week on CGD and make it look much, much better.
Art Kelley
Not the 360i though. I have retired my 175 after many decades of service since using it.
M
Mike Draper
360I is no different. I have had one of those for a year and a half. How do you guys rake those fiber distortions out of cgd?
