Does anyone use the 360i T & G head with the Rotovac CFX, running on standard cold water faucet pressure, as Rotovac claim can be done for the cleaning of T & G??
If so, what results do you achieve?
Also, what is your mean water pressure from a normal cold water faucet over there?
Ours (down under), is approximately 70psi. (I think, as it varies from the high to low areas).
Many thanks.
Many thanks.
