4.7 CDS Throttle control cables
D Rice
Basehor KS
Doug Rice
How difficult is it to install throttle control cables on my HM 4.7 CDS? I really don't want to spend the money to have the dealer do it. I am also installing a new solenoid valve on the side of the mix tank.
Thank you, Doug
AshleyMckendree
Versailles ky
Ashley Mckendree
Go to any local Fleet-Pride or similar truck store and ask for a vernier throttle cable.
A monkey could Install one.
D Rice
Basehor KS
Doug Rice
I don't think that cable would work on my unit. These are very small diameter cables.
Arizona
did they put the same cable with the 2 pods on the 4.7 like they did the 4.8 ????
D Rice
Basehor KS
Doug Rice
Yes, sorry for the wait on the answer. My 4.7 uses the 2 pods with a cable for each one.
Arizona
I use to do mine..just pay close attention to how it is set up...the pods should already be set so if you set the new cables up just like it is you should be OK..If it gets off some then you should be able to tweak it with the pods.....
