6 flow versus 10 flow
handdi
Randy
we got our new truck mount and been playing with the wands
both are ti wands 6 jet
one is 6 flow the new one
one is 10 flow the old wand
For the life of us i can not tell any difference in cleaning with these one cleans just as well as the other
HAs this high flow thing been a farse from day one.
We cleaned dirty carpets so so carpets and can not tell any difference between the 2 flow wands
As far as the heat both about the same maybe goes down 4degrees or so on the 10 flow
What s others thoughts on this matter
Shawn Forsythe
What's the GPM capability of your system? (remember to subtract the flow of your primary machine orifice, if it has one).
What pressure (at the jets) are you running?
Randy;
You are probably only getting slightly more flow on the #10 wand.
Could be a flow limit in your TM.
All things being equal, higher flow should clean better.
Bucket test the actual flows.
