Lonny
- Joined
- Oct 2, 2008
- Messages
- 311
When I look at vacuum motors I am not seeing much if any difference in the air watts of these types of 3 stage vacuum motors. Why would I want to use the larger motors?
Todd Anthony said:The Savage Beast and the Nordic 1 TM both use 2- 7.2 inch 3 stage vac motors. Are you guys saying that these electric TM's are about the same power as a portable unit with 2-5.7 inch 3 stage vac motors? Interesting.
Nate The Great said:[quote="Todd Anthony":2cbt1ojw]The Savage Beast and the Nordic 1 TM both use 2- 7.2 inch 3 stage vac motors. Are you guys saying that these electric TM's are about the same power as a portable unit with 2-5.7 inch 3 stage vac motors? Interesting.
John LaBarbera said:[quote="Nate The Great":3r6ejgbu][quote="Todd Anthony":3r6ejgbu]The Savage Beast and the Nordic 1 TM both use 2- 7.2 inch 3 stage vac motors. Are you guys saying that these electric TM's are about the same power as a portable unit with 2-5.7 inch 3 stage vac motors? Interesting.
Odin said:the 220 motors 7,2 run more volume of air run longer and much cooler than the smaller hi perf now the hotter they get they will lose efficiency and shorten life span. also with better waste tank design and more non restrictive pluming are things you just cant build into a tight space of a portable
John LaBarbera said:Hi Nate The Greater,
I don't know for sure what input hole you're talking about. However, I think your talking about the hole at the bottom of the motor where the suction is. if so, I think they may be the same size. But it doesn't matter since the spec's I mention earlier was regarding each specific motor.
Odin said:a 7.2 will run cooler
The 7.2" diameter 3 stage vacs will run cooler, and last much longer, plus the 7.2" vacs have a larger intake port, and a larger discharge port, than the 5.7" vac motors.Larry said:Bill;
Lamb vac motor engineers utilize AirWatts for their vac motor comparisons.
It measures the peak combination of (lift & CFM) to give a useful power output.
We are using a new 3-Stage 5.7" vac that has 648 AirWatts.
Conventional specs are 153" of lift and 117 CFM.
http://ccs5.com/zen/index.php?main_page ... ts_id=4762
Durability in extraction vac motors is usually determined by bearing life.
The 5.7" vacs have smaller diameter fans. This gives them less rotating mass to unbalance with lint.
The newest with tapered fans are also more efficient, with a given electrical power input.
Larry
